Clutch rod to clutch pedal plastic retainer - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 11-25-2009, 09:10 PM
Eaglefixer Eaglefixer is offline
Eaglefixer is starting off with a positive reputation.
Was driving home last night in my 96 ranger and the clutch pedal when to floor as i was coming to a red light. I had to just hold the brakes and let the motor stall out. The Clutch Master cylinder rod came loose from the clutch pedal. There is a plastic bushing/retainer that holds the rod to the pedal that looks like it broke. Does anybody know if you can buy just the retainer and where can i get it? Dealer maybe. Any part numbers?
Thanks
Steve
Old 11-25-2009, 11:51 PM
XLT2.5L XLT2.5L is offline
XLT2.5L is starting off with a positive reputation.
I would like to know this as well. As you know I just replaced the master cylinder along with everything else, and no matter what I tried to get that clip off in one piece so I could remove the rod from the pedal nothing worked so I just broke it. I havent had any issues with the rod coming off yet in the past week but if you can buy just the clip I would definitely like to put a new one on so I never have to worry about the rod coming off of the pedal.
Old 11-30-2009, 12:24 PM
well it happened again so i just got back from the Ford dealer and bought a new retainer.
Part number 6C3Z7A581A called special retainer Cost $10.81 plus tax
zf6 clutch pedal bushing #'s timmyboy76 1999 - 2003 7.3L Power Stroke Diesel 4 05-19-2016 11:06 AM
Slave cylinder push rod? 94 300 1987 - 1996 F150 & Larger F-Series Trucks 1 01-06-2015 05:29 AM
92 F150 4X4 won't start w/ clutch in and hard to shift milehieagle 1987 - 1996 F150 & Larger F-Series Trucks 1 01-01-2015 10:05 AM
Clutch pedal issue FIXED! Visseroth 1999 - 2003 7.3L Power Stroke Diesel 21 01-14-2012 11:38 AM
F 250 2000 clutch pedal stop Southport 1999 to 2016 Super Duty 2 05-20-2011 05:54 AM
Tags
03, 350, 6c3z7a581a, clip, clutch, cylinder, f350, ford, loose, lutch, master, pedal, pedals, ranger, remove, retaining, rod, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
