Broken track bar mount - Page 2 - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 12-23-2009, 12:56 AM
green 69's Avatar
green 69 green 69 is offline
green 69 is starting off with a positive reputation.
Exclamation track bar bracket
Just my 2cents, I had the same problem with my 99, dealer said they would have to replace the whole front axel.. well I just welded it up, but it broke again so I rewelded it up and added some gussets, Problem solved..
So I see you welded it up but if it was me I would add the extra strength and add some gusset material...
Like I said its just my 2 cents..
Old 12-23-2009, 02:27 AM
rpenterics's Avatar
rpenterics rpenterics is offline
rpenterics is gaining momentum as a positive member of FTE.
Yeah, my pictures don't show it but I did add some bracing across the top of the bracket in a couple places to hold it together to prevent future breakage. Definitely a good idea for anyone who encounters this problem.
Old 10-03-2012, 07:18 PM
rudedogii's Avatar
rudedogii rudedogii is offline
rudedogii is starting off with a positive reputation.
Track Bar no Track Bar?
I just read through all the post on this subject and have some thoughts. First why does it need a track bar? It dont have one in the rear! Right! Well first off look a those stock front leaf springs. Only three leafs! Those will hold the truck up but how about side to side? So it makes sense to me to have a track bar with the factory leafs. My truck has a eight inch lift with a ten leaf pack spring. The spring pack is like 4 inch thick. So I drove it with out the track bar for a few months. Handled the same! It dont need no track bar, right? Months later I started to hear creeking sounds when I turned the wheels Lt to Rt. Checked it out and found cracks in the shackles. I fixed the shackles and re installed the factory track bar. So the track bar has a purpose at least some Ford engineer thought so.
My advise is, if you change the ride height on you you truck. Check that the factory track bar lines back up "after lift" with the factory brackets with no stress! If it dont fit. You may need an adjustable type track bar. I got a track bar video I may upload if any body is interested. That was too much wrighting!
Old 10-03-2012, 07:34 PM
rudedogii's Avatar
Custom track bar bracket
I made this bracket after running with no track bar for a few months.
Track Bar Brackit - YouTube
Old 12-04-2013, 02:30 AM
Burgundy88's Avatar
Burgundy88 Burgundy88 is offline
Burgundy88 is starting off with a positive reputation.
Found the same issue on my 2004 Ex. What is a resonable price for this repair/welding job?
Old 12-04-2013, 10:42 AM
73ferdf250highboy 73ferdf250highboy is offline
73ferdf250highboy is gaining momentum as a positive member of FTE.
A cheap welder from harbor freight is less than $100. I wouldn't pay more than that to get it rewelded
Old 04-28-2014, 05:13 AM
Oilfieldpay Oilfieldpay is offline
Oilfieldpay is starting off with a positive reputation.
Gusset are a must
My track bar was broken I have a 8inch tuff country life with dual steering stabilizers and 37 in bfg A/T. My track bar mount broke, Welded it up No biggie. Now I am on a job driving down the rig road it broke again. I don't have an adjustable track bar I put a link in to strech my oem track bar. Either way If it brakes ADD As Much Metal as you can to make sure it does not happen again because just a weld, Will Fail if your driving conditions remain the same. My track bar is currently in the bed of my truck, To be fixed as soon as a welder show up on the location. I greased my front end thinking that was what was the where the noise was coming from. Half the brake was through the weld have was through unbroken metal.
Old 04-28-2014, 08:25 AM
Burgundy88's Avatar
Adding some gussets is a must, thanks to this forum I made the request at time of service. Front end shop was very leary about making the repair-I guess from a liability standpoint. They only listed the front end alignment on the receipt and I paid for the weld job off the record. Don't know if it was a coincidence, but I had to replace the 4WD hi/low switch on the truck not too long afterwards.
track bar torque???? the78ranger 1999 - 2003 7.3L Power Stroke Diesel 8 01-09-2016 06:35 AM
Broken Lower Track Bar/Steering Damper Mount BigMacWelds 1999 to 2016 Super Duty 4 10-12-2015 09:20 PM
Broken front u-bolt bracket. Replacement? Leeet 1999 to 2016 Super Duty 20 10-01-2015 09:32 AM
track bar bracket broken mudmaker 1999 - 2003 7.3L Power Stroke Diesel 5 09-27-2010 07:06 AM
Track Bar Bracket - Passenger side spring cap? 389sixpack 1999 to 2016 Super Duty 9 05-29-2007 02:30 PM
Tags
2004, 2006, 4x4, axle, bar, bracket, broken, cracking, driving, f250, f350, ford, mounted, trac, track
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
