Modified Intercooler - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 11-25-2009, 07:02 PM
Hardrock_F250's Avatar
Hardrock_F250 Hardrock_F250 is offline
Hardrock_F250 is starting off with a positive reputation.
I went to Charleston SC this morning and while trying to accelerate on the on ramp to I26 the motor sputtered and blew white smoke again. This also happened a month ago and I pulled the intercooler off and drained about a cup of water out of it. After it did it again today I said that when I get back home I was going to fix this problem or at least make it easier to drain the water. I took the intercooler off and there was more than a cup of water in it. I drained it out and proceeded to install a drain ****. The bottom would be the best place but I would have to weld an aluminum piece to it to add depth for the threads. On the side of the intercooler there is a spot that is thick and low enough for the water to drain out. I drilled out a 7/16 hole, tapped it with a 1/4" pipe tap, placed some thread tape, and tighten the drain **** into the intercooler. So far it works great, just start the engine, open the drain **** 1/2 to 1 turn, and the water pours out as if it was on an air compressor tank.
I can't post the pics but here is a link to my albums.
Ford Truck Enthusiasts Forums - Hardrock_F250's Album: Intercooler Mod 2008 F350 6.4
Old 11-25-2009, 07:50 PM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
That is great, maybe the mods can add it and the pics to the tech folder as "Intercooler Fix"
Old 11-26-2009, 01:30 AM
mick1955's Avatar
mick1955 mick1955 is offline
mick1955 is starting off with a positive reputation.
There is a tsb out for the problem you are describing. If your truck is under warranty I would contact Ford. 08-25-1 12/22/2008 Diesel Engine - White Smoke In Cool Humid Conditions
Here's a link to the actual tsb:
Tsb 08-25-1 - TheDieselGarage.com
Old 11-26-2009, 07:20 AM
senix's Avatar
Those that are having problems are not always successful in the new intercooler either. Some still have the issue. It is a design flaw. I am not an engineer but that is my belief.
Old 11-26-2009, 08:41 AM
Maxium4x4's Avatar
Maxium4x4 Maxium4x4 is offline
Maxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputation
Quote:
Done and done... Great information for everyone
Old 11-26-2009, 10:18 AM
ssharber's Avatar
ssharber ssharber is offline
ssharber has a good reputation on FTE.ssharber has a good reputation on FTE.
HardRock has had the new intercooler fix, but is still getting condensation. This is an excellent fix. Glad to see you got it taken care of.
Old 11-26-2009, 10:22 AM
I had that done the first of this year but when the humidity is high the moisture still collects/condenses in the CAC/intercooler. Now I can drain it out without having to take the unit off. I live in SC and the humidity has been high here for about two months straight.
Old 11-26-2009, 10:37 AM
ZeroOne's Avatar
ZeroOne ZeroOne is offline
ZeroOne is starting off with a positive reputation.
This idea had been shot down previously, with concerns of weakening the intercooler, but it looks like you've managed to do it in a way that addresses this. Great post! Wish I'd just done this instead of going through the TSB hassle.
Old 11-26-2009, 10:57 AM
Maxium4x4's Avatar
Know if you can figure out how to make the drain automatically dump like my air compressor
Old 12-21-2010, 06:02 PM
Bounds-Electric's Avatar
Bounds-Electric Bounds-Electric is offline
FORD USER
Bounds-Electric is gaining momentum as a positive member of FTE.
Quote:
I put a 12 volt air valve on mine to switch 4 . Once a week turn on
(open) with truck off or running to dump water!
Old 12-22-2010, 09:07 PM
Do you have any pics of your install?
RSS backup alarm on when in reverse??? Hardrock_F250 1999 to 2016 Super Duty 0 07-25-2015 09:54 PM
Tested a new intercooler from Alradco weekendwarriorfsw32 6.0L Power Stroke Diesel 8 04-17-2014 03:45 AM
1949 F3 Parts Advice Needed 49truck 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 02-09-2011 06:43 PM
Replacing Radiator Drain Cock arigsby Ranger & B-Series 2 05-30-2010 07:33 PM
6.4L Diesel: 6.4 Tech Folder kw5413 6.4L Power Stroke Diesel 1 07-06-2009 08:26 PM
Tags
08, 08251, 20082009, 64, 64l, diesel, f350, ford, intercooler, intercoolers, modified, pipe, truck, tsb, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
