Torque Specs for 2000 F-350 Wheel hub assembly
Replacedthe left front wheel hub assembly on my 2000 F-350 DRW. I have two very different torque specs for the mounting bolts to the steering knuckle. One is 55ft/lbs and the other is 155ft/lbs. Which is correct or is it something different? Don't want to lose the $200-500 assembly(depending on where you purchase it)
Chilton's?
Sure.
Those guys can be idiots. Their writers are..... writers, and are sometimes not very-well-versed in the finer points of wrench-turning.
A reasonableness cross-check would have caused them to investigate their published spec more carefully, but...... well, you know.......
And that's what we just did here, a reasonableness check. A lot of folks looked at that number and instinctively said, "Uhhh, let's look that one up again."
It just didn't look right, especially when it comes to holding one of the wheels onto a large pickup truck. You might find a Prius uses that number.
When in doubt, I usually consult Guzzle's pages, as he is a real stickler for details being correct. See:
http://www.guzzle7pt3.com/nblube.php
Pop
Sure.
Pop
Ford's spec is 133 ft-lbs.
Attachment 19063
I've done a few of these and just used a long handle ratchet or breaker bar to tighten them up.
Attachment 19063
Don't toss it completely, as there are photos in there that may contribute to your understanding of something.
They can't dork up a photo, at least not too badly....
Of course, they could show a photo that doesn't explain a thing, or even confuses, but.....
Just put the Chilton's on the bottom of the pile, and use it last.
Pop
Pop
Whitey Ford
11-01-2020 07:55 AM
Buck268
09-24-2016 11:00 PM
