Torque Specs for 2000 F-350 Wheel hub assembly - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 11-25-2009, 08:34 AM
stemwill stemwill is offline
stemwill is starting off with a positive reputation.
Replacedthe left front wheel hub assembly on my 2000 F-350 DRW. I have two very different torque specs for the mounting bolts to the steering knuckle. One is 55ft/lbs and the other is 155ft/lbs. Which is correct or is it something different? Don't want to lose the $200-500 assembly(depending on where you purchase it)
Old 11-25-2009, 08:45 AM
SGnAZ's Avatar
SGnAZ SGnAZ is offline
SGnAZ has a very good reputation on FTE.SGnAZ has a very good reputation on FTE.SGnAZ has a very good reputation on FTE.
Hub bearing to steering knuckle nuts-55ft-lbs
Old 11-25-2009, 09:04 AM
That was what I was thinking. 155lbs would probably snap/strip the studs or pull the assembly through the knuckle. Thanks.
Old 11-25-2009, 09:07 AM
SGnAZ's Avatar
Quote:
Originally Posted by stemwill View Post
Thanks.
You're welcome
Old 11-25-2009, 09:16 AM
mueckster's Avatar
mueckster mueckster is online now
aka Redneck Wrencher
mueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputation
Ford's spec is 133 ft-lbs.
Name:  hub to knuckle torque.gif
I've done a few of these and just used a long handle ratchet or breaker bar to tighten them up.
Old 11-25-2009, 09:53 AM
SGnAZ's Avatar
I stand corrected
The specs I got were from a Chiltons manual.
Could they really be that far off like that
Old 11-25-2009, 12:37 PM
SpringerPop's Avatar
SpringerPop SpringerPop is offline
Too old to be too smart..
SpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputation
Chilton's?
Sure.
Those guys can be idiots. Their writers are..... writers, and are sometimes not very-well-versed in the finer points of wrench-turning.
A reasonableness cross-check would have caused them to investigate their published spec more carefully, but...... well, you know.......
And that's what we just did here, a reasonableness check. A lot of folks looked at that number and instinctively said, "Uhhh, let's look that one up again."
It just didn't look right, especially when it comes to holding one of the wheels onto a large pickup truck. You might find a Prius uses that number.
When in doubt, I usually consult Guzzle's pages, as he is a real stickler for details being correct. See:
http://www.guzzle7pt3.com/nblube.php
Pop
Old 11-25-2009, 01:00 PM
mechelement's Avatar
mechelement mechelement is offline
mechelement has a good reputation on FTE.mechelement has a good reputation on FTE.mechelement has a good reputation on FTE.
Quote:
Attachment 19063
133lbs-ft is what I used on those bolts.
Old 11-25-2009, 01:10 PM
SGnAZ's Avatar
I'll stick with you guys and toss the Chiltons.
Old 11-25-2009, 01:15 PM
Don't toss it completely, as there are photos in there that may contribute to your understanding of something.
They can't dork up a photo, at least not too badly....
Of course, they could show a photo that doesn't explain a thing, or even confuses, but.....
Just put the Chilton's on the bottom of the pile, and use it last.
Pop
F-450 rear brake job Shake-N-Bake 1999 - 2003 7.3L Power Stroke Diesel 35 12-20-2015 08:48 PM
Proper torque for aftermarket wheels F350Centurion 1999 to 2016 Super Duty 4 11-30-2012 06:31 PM
Torque Specs for 2000 F-350 Wheel-Hub Assembly to steering knuckle stemwill 1999 - 2003 7.3L Power Stroke Diesel 1 11-25-2009 09:09 AM
Spark Plug Torque Spec on a 1999 F-250 Stone Mathews Modular V8 (4.6L, 5.4L) 1 03-21-2008 09:52 PM
torque specs Nikolai 1999 to 2016 Super Duty 3 08-16-2007 06:41 PM
Tags
1997, 2000, 2001, 2002, 73, end, f250, f350, ford, front, hub, specifications, specs, torque, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
