Surging 6.9 at idle
Surging 6.9 at idle
well well well i havent drove my truck in a couple weeks.. took it for a spin tonigh and it runs and drives great, pleanty of power, 84 6.9 non turbo diesel in my 75 ford crew cab.. but at idle once in a while it will rev up now.. i wonder if this could be a indication of bad diesel, or maybe water in the diesel? i have no water seperator on this truck, and havent had one in years.. i did change my fuel filter last month..
anyone ever experiance a reving up and back to idle while in neutral and at stop lights? it did it a few times in a row at a couple stops.. it like somone is reving it up fo ra second then lets off.. the operating temp was up to about 200F during the time i drove it tonight, and that seems to be normal for this truck
Any ideas?
Ray
Any ideas?
Ray
My first two thoughs are either air intrusion or the IP govenor sticking a little.
How well did it start?
If it fired right up and did not die very shortly after that, you can probably rule out air intrusion.
So that would leave a drain the filter and fill it with Diesel Kleen, then start the engine and shut it off after 10 seconds and let it sit for a couple hours before restarting to clean out and lube the IP internal linkages.
fires up like a champ everytime, it has never died on me, and i replaced all the rubber lines last year with one of them kits with the injector caps and hose and orings and such..
I will pull the fram filter off.. and put another new one on full of diesel kleen.. liek you suggest..
Thanks
Ray
FarmallM4
19
03-27-2016 09:52 PM
86dieselnut
11-15-2015 05:29 PM
DRRXR
44
11-28-2011 06:25 PM
88fordranger
12-12-2005 07:32 PM
