fuel tank filler tube - Ford Truck Enthusiasts Forums
Old 11-24-2009, 08:34 PM
Roy C Roy C is offline
Roy C is starting off with a positive reputation.
My son and I are fixing up a 1987 F150 that has dual tanks. We took the rear tank out to replace the sending unit and pump and in doing this we ended up cutting the filler tube. There were actually 2 tubes, one inside of the other. This is only my second tank I've ever dropped and I don't remember the other one having 2 tubes. It was a 97 Suburban and it had only one filler tube. Does the filler tube going back have to be constructed that way or can it be a single tube?
Thanks....
Old 11-25-2009, 07:01 AM
LCAM-01XA LCAM-01XA is offline
LCAM-01XA has a very good reputation on FTE.LCAM-01XA has a very good reputation on FTE.LCAM-01XA has a very good reputation on FTE.
This concentric-hose setup is Ford's way of saying "eff you" to the customer - basically when you fill the tank the fuel flows through the inner hose, and the air it displaces in the tank gets pushed out through the gap between the inner and outer hose - if you have a gas-powered truck this means it takes you forever to fill up your tanks, and if you have a diesel like me it leaves you stuck looking for a car-diesel pump and then trying to get to it with a big trailer. There is a solution to the problem, it involves removing the rollover valve from the top of the tank and installing a barb-hose fitting in its place, then running a large hose from said fitting to the filler neck where you drill a hole and weld/braze on another fitting - now you can remove the inner filler hose and use the full diameter of the outer filler hose to pump fuel in, and the air will get vented through the top of the tank and that hose that you added. Basically you're creating an external vent for the tank (like many older Chevy and Dodge trucks have), it still vents inside the metal filler neck like factory, only you can pump fuel in faster and in case of a diesel truck you can now use the big-truck pumps at any truck stop. It should be mentioned that to keep things legal you probably need to add a small atmosphere vent somewhere, I've seen people t-ee that off the big vent hose.
Old 11-25-2009, 10:22 AM
Thanks for the info.
Old 11-25-2009, 01:19 PM
you're welcome
Gas filler tube for '66 F100 robbm 1961 - 1966 F-100 & Larger F-Series Trucks 2 08-28-2010 11:29 PM
Fuel filler neck for rear tank? smashclash 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 07-26-2010 11:21 PM
97 f150 gas filler tube leaking Sarpy Creek Bo9y 1997 - 2003 F150 3 03-28-2009 02:58 PM
56 Filler tube? imlowr2 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 03-25-2006 02:51 PM
Fuel filler tube TDean 1987 - 1996 F150 & Larger F-Series Trucks 11 10-11-2002 09:45 AM
Tags
diesel, f150, f350, fill, filler, ford, forever, fuel, hole, hose, inside, neck, size, takes, truck, tube
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
