1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Right Turn Signal dont work with headlights on!!HELP
Old 11-24-2009, 01:37 PM
sonicsaleen's Avatar
sonicsaleen
sonicsaleen is offline
Has anybody had this problem before, i know one other truck 08 f350 that has the same problem only other side.
My turn signal blinks fast on the right side but all lights work, when the headlights are on or parking lights the front right blinker doesnt work. I dont know what to do?
Old 11-24-2009, 01:48 PM
R-T0r21on's Avatar
R-T0r21on
R-T0r21on is offline
Is it still under warranty? If yes, take it to the dealer. If not, try a new bulb.
Old 11-24-2009, 02:24 PM
sonicsaleen
The bulb works, No warranty
Old 11-24-2009, 02:32 PM
69cj's Avatar
69cj
69cj is offline
If all the bulbs are good you probably have a bad flasher
Old 11-24-2009, 02:53 PM
senix's Avatar
senix
senix is online now
Received 1,415 Likes on 1,010 Posts
sounds like the flasher to me if it is flashing really fast. Change that and then tell us if that fixed it.
Old 11-26-2009, 10:27 AM
ssharber's Avatar
ssharber
ssharber is offline
My '08 has gone through about 6 rear bulbs in 40,000 miles. Usually its the left turn signal, but the right one does it also, just not as much. The brake and tail light portion of the bulb works (notice, the rear has only one bulb for brake, turn and tail), but the turn is the one that goes. And there are heat marks at the base of the bulb. Like it was sitting on a heater. Scorch marks actually. I had it looked at and was told that was normal. BS. So now I carry a pack of bulbs and a nutdriver with me. In fact, yesterday I hit the blinker and she started the fast dance, which is my indication that the bulb has blown the flasher portion. Changed it out and I'm good for another 8k or so. Ridiculous I know, but with the dealer stating its normal, even though I dont believe them, I have no recourse. Tired of arguing with these guys.
Old 11-26-2009, 11:10 AM
kane gray's Avatar
kane gray
kane gray is offline
You must have a short. The dealers don't care enough sometimes to look for the real problem. I would just track the harness going up to that light, and look for any points where it could be pinched, or rubbing. Just an idea.
Old 11-26-2009, 11:13 AM
senix's Avatar
senix
senix is online now
Should be pretty easy to remove the light and fixture and look at those wires to see if they are rubbing.
Old 11-27-2009, 09:46 AM
WhëëlMå1's Avatar
WhëëlMå1
WhëëlMå1 is offline
moved to Super Duty
thatsrealnice
16
07-31-2020 06:00 PM
Zacbkennedy
07-08-2017 12:11 AM
red97stroker
21
12-02-2016 12:19 PM
three.on.the.tree
21
04-21-2016 06:36 PM
B-Rad31302
11-10-2015 02:04 PM
Quick Reply: Right Turn Signal dont work with headlights on!!HELP
