Problem removing Crankshaft Spacer
The Truck: 77 F250 Camper Spec. 460 2wd.
Ok I have all the bolts removed from Timing chain cover, water pump is already pulled and the harmonic balancer is off. When I tried to remove the spacer I noticed that it is not lined up with the key way so I tried to to turn by hand and it will not spin only move slightly in and out. I tried to rotate crankshaft by hand with no luck. Any input is greatly appreciated. I am pretty sure it needs to be removed to remove timing cover as old timing cover is corroded through and I have new one already.
http://i201.photobucket.com/albums/a...8/DSC01627.jpg
http://i201.photobucket.com/albums/a...8/DSC01626.jpg
anotherhappycamper
1978 - 1996 Big Bronco
06-06-2013 08:17 AM
nkenney
Paint & Bodywork
01-10-2012 11:10 AM
C.Thompson
12-17-2009 04:14 PM
