2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Install Rear Seat DVD?
Old 01-16-2010, 02:58 PM
08 Navigator's Avatar
08 Navigator
08 Navigator is offline
Has anyone ever installed a rear seat DVD player in a truck that came from the factory without one? I bought a player and cable on line for a hundred bucks, and now I'm wondering if it is more trouble than it is worth to install.
I've got a 2008 Navigator with an OEM navigation system.
Any thoughts? Thanks.
Old 01-16-2010, 10:10 PM
TIKT B8's Avatar
TIKT B8
TIKT B8 is offline
Are you talking about an OEM system or an aftermarket system?
Old 01-16-2010, 11:11 PM
08 Navigator
It's an OEM rear DVD player, one of those roof mount units. It's got a cable that plugs into the factory harness somewhere in the left rear kick panel.
I haven't looked under the headliner, so I don't know if it needs some sort of bracket or not.
I was hoping someone on this board had done this upgrade. The parts are cheap on eBay,
Old 01-17-2010, 10:45 PM
TIKT B8's Avatar
TIKT B8
TIKT B8 is offline
I am not sure if there is a bracket or how it is mounted but that should not be a problem either way. Check with the dealer and get an exploded view of how it is mounted. The cable is usually the hardest part to locate unless you buy it from the dealer$$ so you got lucky.
Another thing to consider is that you will have to send your navigation unit off to get reprogrammed for the dvd control (so you can play,pause, etc the dvd from the nav unit) That runs about $90.
Callmed
09-04-2016 03:26 PM
F100Ford
05-03-2016 10:11 AM
ithaca1230
05-17-2014 07:31 PM
VQT
01-24-2012 09:41 PM
cenni jimenez
32
12-07-2010 10:14 PM
Quick Reply: Install Rear Seat DVD?
