Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1961 - 1966 F-100 & Larger F-Series Trucks > 1961 - 1963 F100 Unibody
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
  #1 (permalink)
Old 11-23-2009, 03:26 PM
madcitymike madcitymike is offline
Garage is empty, add now
madcitymike is starting off with a positive reputation.
63 front end upgrades?
I'm a 60's Ford truck newb, but am very familiar with 70's Fords, so hopefully some of that will carry over, but essentially I am helping out a buddy who just picked up a 63 F100. It's an old school ice cream truck with a convertable canvas top over the cab, no doors, and a low profile freezer box tucked between the flare side fenders instead of a bed. Right now the steering gear is stripped so it doesn't steer. I've done a lot of 4x4 fab and modification so we don't necessarily need bolt on upgrades, but essentially since the steering gear has to get replaced, is there a P/S upgrade from a newer truck that will work? Looking at other posts, it looks like if this were a 65 or 66 truck it would be a no brainer, but I'm not seeing much for options to upgrade this 63. At the same time, disk brakes would be nice and going to TIB would be a nice upgrade from the leaf sprung monobeam. Is there a better option at this point other than welding in the front end of a newer truck? Since the bed is a custom job freezer instead would it make any sense to just try to put the bodywork from the 63 onto a newer complete frame? I keep hearing reference to a unibody for this era of Ford trucks. What does that signify? Did they actually have true unibody trucks back then? My buddies truck has a real frame.
-Mike
  #2 (permalink)
Old 11-23-2009, 06:39 PM
37 Ford guy's Avatar
37 Ford guy 37 Ford guy is offline
1966 Ford F-100
37 Ford guy is gaining momentum as a positive member of FTE.37 Ford guy is gaining momentum as a positive member of FTE.
Quote:
-Mike
Hey Mike,
There are all kinds of options depending on how much money he wants to spend. There is a bolt-on power rack & pinion kit for the straight axle that runs around $700+. Disc brake kits are also available for the straight axle. I've also heard of installing a power gear box from a toyota but not sure which one.
If he wants to change to independent front suspension, he could install the crossmember from an 03 or newer Crown Vic and get power rack & pinion plus big disc brakes. Do a search of the forum. Several guys have done this.
Another option is a custom crossmember using all suspension components from a Dodge Dakota. This is a nice setup too. You can search for that too.
As for fabbing in twin-i-beam or frame swapping, personally I think that would be a step backwards for a variety of reasons.
Hope that helps get you started....
Oh....the "unibody" was built by Ford from 61-63. The cab & bed were joined together but it still mounted to a full frame. It was sorta like an El Camino.
  #3 (permalink)
Old 11-24-2009, 05:33 AM
jowilker's Avatar
jowilker jowilker is offline
1966 Ford F-100
jowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to behold
jowilker jowilker
Mike, No later model up grades for pre-Twins, sorry. Don't know all I know about those trucks, but does it have 5 or 8 wheel lugs? There were Good Humor ice cream trucks that were similar as what you describe. I don't know the first year for them.
The calls for a Number Dummy response.
John
__________________
In the cool still quiet hours of night, you can hear chevies rusting away.
  #4 (permalink)
Old 11-24-2009, 11:50 AM
jhooch's Avatar
jhooch jhooch is offline
jhooch is gaining momentum as a positive member of FTE.
Check out the first issue of True Blue Ford Trucks Magazine. They did a story on the Good Humor ice cream trucks.
__________________
Jeff
'05 Excursion LTD 6.0 4X4, 01 F250 7.3 4X4 Crew
73 Bronco, 66 F100 CC LWB, 62 Uni LWB
69 Cobra 428CJ, 4-speed, 64 Fairlane 2dr Post
See my other projects at: www.fullsizeford.com
  #5 (permalink)
Old 11-24-2009, 04:39 PM
salf100's Avatar
salf100 salf100 is offline
salf100 is new and has a neutral reputation at this point.
Theres a company in CA called "No Limit" and they offer a complete weld in front clip that has discs and power steering...its a bit pricey though.
Tags
6163, 63, axle, bolt, chrome, end, f100, ford, front, grill, pinion, power, rack, references, solid, steering, truck, trucks, unibody
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
