Stumped with my Dana 60, please advise
Alright guys, I pulled the diff cover off and everything looks fine. However the passenger side axle shaft u joint is resting on the ball joint, so I know there is stress on its respective spider gear. When I wiggle the axle shaft I can see the spider gear has some lateral play to it. I am at the point where I am unsure if I need to replace the diff or just the passenger side bearing assembly. How can I diagnose if there is critical damage I cannot see to spider gears/ carrier assembly? I can't really afford to buy parts I dont need, but I want this to be fixed properly.
As of now, the differential isn't in as poor of shape as I had suspected. Anyone have any advice on what I should do? What to look for regarding internal damage to my gear set?
Thanks in advance!
Thanks in advance!
Well what do you mean angle at the spider gear? The axleshaft is intact I'm just worried about that torque on the spider gear from the long axle shaft not being suppoted on the wheel bearing end of the big axle. Everything looks fine, I just dont want to think its fixed and then have it break again
Well I've already pulled the shaft, I just don't know how to diagnose if my differential is indeed damaged or not... the axle shaft is a gonner, but I just find it hard to believe that all the torque of the axle shaft on the spider gear didnt damage it in some way shape of form. Is there a diagnosis procedure?
Were you using 4x4 while this was like this? If not, you have NOTHING to worry about. And if you were, you'd have heard a lot of noise, and stopped, right?
The only thing that might be an issue is the oil seal in the axle tube might need to be replaced.
Post up a pic of the bad shaft so we can take a look.
Krewat, I tried to use 4x4 once and it completely didn't work so I turned it off and used my girl friend's dads chevy to pull me out of the ditch. This was before the hub melted down... other than that I've had no need for 4x4. But I do have an interesting picture here of what happened when my 4x4 went out. I'm glad my GF's dad had a sense of humor about my attempted escape from the ditch
AS PROMISED, HERE'S THE DAMAGE PICS
I honestly am starting to believe the diff is fine, the spider gears are tight to my fingers and only rotate, no play without the axle helping them. So here's the pictures, will caption beneath
Starting out... nice hot spots on them rotors, yay.
While trying to remove the rotor the whole wheel bearing came out. Rotor is still on it, but ehh no biggie. Not that it's off the truck I have more room to apply my BFH. Ironically, that don't look like I remembered. I think this is catastrophic wheel bearing failure
My memory aint as good as she used to be, but I vaguely remember needle bearings in there. Hmmmm.... definitely catastrophic wheel bearing failure
As you can see in this example, the axle is FUBAR. You can see where my U-Joint banged up my ball joints. It took the grease fitting off and 'forged' the bottom of the top u- joint flush with the knuckle and made the threaded portion of the bottom u joint smoosh over the nut holding it in. Happy Days
