1967 F100 4x4 Suspension, Rims and Tires
Hi:
I am sorry for such an easy question for most of you but this is my first F100 and my first project without the help of my old man so naturally I am lost. I just bought a 1967 F100 4x4 and I am looking to put new rims and tires on it. A guy has a F150 Ranger locally with 35x12.5 R15's on it with American Racing Baja's I believe that look good. I am considering this set-up and wondering what else I need to do this conversion. Do I need a new suspension/driveshaft/etc?
Also, any pictures you have of your ride height with sizes, brands, tips etc would be great.
Thanks so much.
James
Thanks so much.
James
James, welcome to FTE! I'm in the midst of doing my 67 restore. I'm going to go with the Skyjacker 3"lift on mine. I know for the 3" it's around $250, if I remember right. Basically, you'll have to change out the front springs (pretty easy) and install lift blocks in the rear end. May have to change the C-bushings on the front axle, to change the pinion angle of the front driveshaft.
Here is a link to the kit I'm getting:
3.5-4" 66-72 Ford F100/F150 4x4 Skyjacker Lift Kit !! - Top Gun Customz
I got a 68 f-100, it has 36-12.5-15 on it now with a 6inch lift kit and they clear no problem. Depends on what your doing, if its just for the road a 4inch could be fine for 35s but if you need some travel then a 6inch would be better. Problem with a 6inch is, you end up with 6inchs of blocks in the rear cause there aint any lift leaf springs to be had on the easy/cheap.
Mister_King
15
10-20-2019 10:06 AM
Gunter Ettel
19
11-17-2016 09:25 AM
rwbjur
22
12-05-2015 09:20 PM
Mister_King
03-14-2015 04:06 AM
