1967 F100 4x4 Suspension, Rims and Tires
Old 11-23-2009, 01:42 PM
rocketma1n's Avatar
rocketma1n
rocketma1n is offline
Hi:
I am sorry for such an easy question for most of you but this is my first F100 and my first project without the help of my old man so naturally I am lost. I just bought a 1967 F100 4x4 and I am looking to put new rims and tires on it. A guy has a F150 Ranger locally with 35x12.5 R15's on it with American Racing Baja's I believe that look good. I am considering this set-up and wondering what else I need to do this conversion. Do I need a new suspension/driveshaft/etc?
Also, any pictures you have of your ride height with sizes, brands, tips etc would be great.
Thanks so much.
James
Old 11-23-2009, 11:59 PM
jhooch's Avatar
jhooch
jhooch is offline
A 4-inch suspension lift would be the way I would go.
Old 11-29-2009, 02:02 PM
Doug F's Avatar
Doug F
Doug F is offline
Hi James, I too have one of these rare 4wd F-100s and have found that Superlift and Skyjacker both offer lift kits for our trucks. I haven't gotten to the suspension lift part yet, but have done my research.
Good luck to you!
Old 11-29-2009, 04:35 PM
67nukeford's Avatar
67nukeford
67nukeford is offline
James, welcome to FTE! I'm in the midst of doing my 67 restore. I'm going to go with the Skyjacker 3"lift on mine. I know for the 3" it's around $250, if I remember right. Basically, you'll have to change out the front springs (pretty easy) and install lift blocks in the rear end. May have to change the C-bushings on the front axle, to change the pinion angle of the front driveshaft.
Here is a link to the kit I'm getting:
3.5-4" 66-72 Ford F100/F150 4x4 Skyjacker Lift Kit !! - Top Gun Customz
Old 12-01-2009, 04:44 PM
Xeen1901's Avatar
Xeen1901
Xeen1901 is offline
I think a four inch kit will work for those. I'm in the process of doin a 10 on my 67. Will let you know what that clears in a about a week. Using 6 inch springs front w/ lowered mounts and radius arm drops, 7 degree c bushings.remounting rear spring perches with 6 inch springs in rear.
Old 12-01-2009, 07:04 PM
Doug F's Avatar
Doug F
Doug F is offline
Have you guys seen BC Bronco's front radius arm kit and rear spring pivots? Not sure what kind of off-roading you are planning, but they will help your articulation a LOT!
Old 12-02-2009, 06:41 PM
bigred f-100's Avatar
bigred f-100
bigred f-100 is offline
I got a 68 f-100, it has 36-12.5-15 on it now with a 6inch lift kit and they clear no problem. Depends on what your doing, if its just for the road a 4inch could be fine for 35s but if you need some travel then a 6inch would be better. Problem with a 6inch is, you end up with 6inchs of blocks in the rear cause there aint any lift leaf springs to be had on the easy/cheap.
Mister_King
15
10-20-2019 10:06 AM
Slade40
2017+ Super Duty
03-07-2017 02:06 PM
Gunter Ettel
19
11-17-2016 09:25 AM
rwbjur
22
12-05-2015 09:20 PM
Mister_King
03-14-2015 04:06 AM
Quick Reply: 1967 F100 4x4 Suspension, Rims and Tires
