1967 F100 4x4 Suspension, Rims and Tires - Ford Truck Enthusiasts Forums
Old 11-23-2009, 02:42 PM
rocketma1n rocketma1n is offline
rocketma1n is starting off with a positive reputation.
Hi:
I am sorry for such an easy question for most of you but this is my first F100 and my first project without the help of my old man so naturally I am lost. I just bought a 1967 F100 4x4 and I am looking to put new rims and tires on it. A guy has a F150 Ranger locally with 35x12.5 R15's on it with American Racing Baja's I believe that look good. I am considering this set-up and wondering what else I need to do this conversion. Do I need a new suspension/driveshaft/etc?
Also, any pictures you have of your ride height with sizes, brands, tips etc would be great.
Thanks so much.
James
Old 11-24-2009, 12:59 AM
jhooch's Avatar
jhooch jhooch is offline
jhooch is gaining momentum as a positive member of FTE.
A 4-inch suspension lift would be the way I would go.
Old 11-29-2009, 03:02 PM
Doug F Doug F is offline
Doug F is starting off with a positive reputation.
Hi James, I too have one of these rare 4wd F-100s and have found that Superlift and Skyjacker both offer lift kits for our trucks. I haven't gotten to the suspension lift part yet, but have done my research.
Good luck to you!
Old 11-29-2009, 05:35 PM
67nukeford's Avatar
67nukeford 67nukeford is online now
Nebraska Chapter LDR
67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation
James, welcome to FTE! I'm in the midst of doing my 67 restore. I'm going to go with the Skyjacker 3"lift on mine. I know for the 3" it's around $250, if I remember right. Basically, you'll have to change out the front springs (pretty easy) and install lift blocks in the rear end. May have to change the C-bushings on the front axle, to change the pinion angle of the front driveshaft.
Here is a link to the kit I'm getting:
3.5-4" 66-72 Ford F100/F150 4x4 Skyjacker Lift Kit !! - Top Gun Customz
Old 12-01-2009, 05:44 PM
Xeen1901 Xeen1901 is offline
Xeen1901 is starting off with a positive reputation.
I think a four inch kit will work for those. I'm in the process of doin a 10 on my 67. Will let you know what that clears in a about a week. Using 6 inch springs front w/ lowered mounts and radius arm drops, 7 degree c bushings.remounting rear spring perches with 6 inch springs in rear.
Old 12-01-2009, 08:04 PM
Have you guys seen BC Bronco's front radius arm kit and rear spring pivots? Not sure what kind of off-roading you are planning, but they will help your articulation a LOT!
Old 12-02-2009, 07:41 PM
bigred f-100's Avatar
bigred f-100 bigred f-100 is offline
bigred f-100 is starting off with a positive reputation.
I got a 68 f-100, it has 36-12.5-15 on it now with a 6inch lift kit and they clear no problem. Depends on what your doing, if its just for the road a 4inch could be fine for 35s but if you need some travel then a 6inch would be better. Problem with a 6inch is, you end up with 6inchs of blocks in the rear cause there aint any lift leaf springs to be had on the easy/cheap.
1967 F100 4x4 - Tire Recommendations (Lifted) Mister_King 1967 - 1972 F-100 & Larger F-Series Trucks 12 03-14-2015 05:06 AM
1967 F100 4x4 - Original Wheels Mister_King 1967 - 1972 F-100 & Larger F-Series Trucks 14 02-23-2015 11:51 AM
1967 F100 4x4 Drum Brake Overhaul Mister_King Brakes, Steering, Suspension, Tires, & Wheels 0 01-21-2015 04:56 AM
'67 F250 Project - Porting Heads and stuff TheLetUp 1967 - 1972 F-100 & Larger F-Series Trucks 77 07-26-2014 04:12 AM
Need to replace Split Rims slammers 1967 - 1972 F-100 & Larger F-Series Trucks 2 04-10-2010 11:41 PM
Tags
100, 1967, 4x4, 67, club, conversion, f100, ford, lift, lifted, restore, rims, suspension, tires, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
