tach speedometer gauges not working - Ford Truck Enthusiasts Forums
Old 11-23-2009, 01:43 PM
Steveg13 Steveg13 is offline
Steveg13 is starting off with a positive reputation.
Tach , speedometer, compass, milage,don't work gauges go to mid point but don't read auto lights doesn't shut lights off when the key is off and the door opened - same story with the radio
all was working fine on the way to the store - not working when I started up to return home
beyond that it runs great - shifts ok and not other problems
I have climbed all over looking for a lose connector - blown fuse - no luck
any suggestions?
1965 F-100 speedometer gauges and lights Fords & Whalers WTB - Parts & other 2 08-29-2016 10:56 PM
speedometer and overdrive light maitai 1 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 1 09-09-2013 03:43 PM
Cluster swap: stuck tach? twincam00 1987 - 1996 F150 & Larger F-Series Trucks 8 12-02-2012 10:12 PM
make a real oil pressure gauge lmd91343 1987 - 1996 F150 & Larger F-Series Trucks 6 02-14-2012 10:35 AM
2006 Explorer speedometer, tach, gauges out srwells Explorer, Sport Trac, Mountaineer & Aviator 0 05-24-2010 05:52 PM
Tags
1991, 2002, 2003, explorer, f150, f250, ford, gauges, speedo, speedometer, sport, tach, trac, working, works
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
