Green Antifreeze on bottom of trans dust plate and oilpan!
I hopped under my truck to check my rear main seal leak and the first thing I noticed was that it appears the rear of my oil pan is leaking too or that's what WAS leaking because oil was coming from above the dust plate. But then with an even closer look I saw a green tint as if their was antifreeze down there and it has to be. Also on my oil pan around my drain plug there was green fluid forming into a drip... Does this mean bad head gaskets? or worse?
You need a "Radiator pressure tester" some parts stores rent them. All this tester is is a hand operated plunger that pushes air into your radiator to pressurize the system. Make sure your cooling system is full, then take the cap off of your radiator, and attach the adaptor at the end of the hose of the tester. Then start pumping the handle, the tester will have a guage on it, DO NOT exceed the pressure stated on your radiator cap Usually 15-16 psi.
With the system up to pressure, climb under your truck and follow the stream of coolant back to the source.
If you are uncomfortable doing it yourself, or do not want to buy/rent the tester, then take it to a shop and have them do it, but make sure that they show you were the leak is coming from, there are some shady shops out there that will try to sell you an engine rebuild when all you may need is a 5 dollar freeze plug.
Good luck and let us know what you find.
Most likely causes for a coolant leak In order, radiator hoses, heater hoses, Thermostat gasket, radiator, waterpump, Freeze plug/block heater.
Be glad it's not a chevy otherwise I would tell you (without even looking at it) it is the lower intake, Usually about an $1,000-$1,500 job. (only reason I like chevys, they make us mechanics rich )
If you choose to try and find it yourself and it is not obvious like a hose or thermostat housing.
Start at the waterpump weep hole and next check the water passage weep hole on either side of the timing case.
The fan can blow coolant a long way back under your truck.
This is just my personal experience with my truck, but may save you some time.
Yes, don't focus on one part, that is why in my 3rd post i listed the most common sources for coolant leaks in order. I only brought up freeze plugs as an example of a cheap fix, instead of an expensive head gasket.
