Disk brakes for '69 F100
Hey I'm working on a '69 F100 2WD, with drum brakes all around. Does anyone know a cheap, painfree way of swapping the front drums off for some disks. Would they swap across from a '73-'79 truck? Also my brakes are manuel, so I'd need a brake booster - would a '73-79 work?
The cheapest way to go would probably be to get the parts from a '73-79. They also make kits for a disc brake swap but they are outrageously expensive. Or you could find a bump with disc brakes I believe in '71 they made them an option (not 100% sure what year), I will send you a few links in a min. or two once I dig them up explaining the disc brake swap from a '73-79 onto one of our wonderful bumps.
Hey I noticed you were a new member as well, welcome, I can't post the links as the site doesn't like it when we reference other sites but, I'd look up a site that starts with ford and ends with a word ryhymes with information. There's a great write-up on there under the Tech articles section. Also Carcrafter did a swap with a newer Crown Vic front end to take advantage of a smoother-ride with disk brakes and just an overall more modern suspension you can look it up in this forum, it would be very informative to you as well.
Check the donor out for front end tightness before you buy, and you will have all the parts to upgrade power steering and disc brakes.
There are little parts that can eat your lunch when left behind, so buy it and bring it home. A towing company will come get the carcus for free when you are done.
John
Here is a quick link to the questions you asked....https://www.ford-trucks.com/forums/4...-for-info.html
First disc brakes on F100 2WD's: 1973. Thru 1979, manual discs were standard equipment, power discs were optional.
First disc brakes on F100/150 & F250 4WD's: 1976.
I also have a ? I just removed the drivers side spindle and hub off my 1968 F100, if I wanted to go to disk brakes on the front could I just swap out the I beams and leave the king assembly together? And if so what years would work? 1971-1979????
Me I have a 12 ton press I halled that dude out side, fitted it under my fender well and pressed that King pin out.
Thanks jowilker, one more thing I I want just be sure of.
I went into a new parts facility, A guy there said when I mentioned turning my 360 into a 390 all I had to do was change crank and pistons, he said the rods were the same???
Another thing he said he owns 3 FE engines all have C6 trany? is it so?
The 360 is the same block & bore as the 390. It uses a 352 crank & rod set, so to upgrade the rods must also be swapped with the crank.
All FE blocks have identical bell patterns, there is a C6 FE bell, so your friend could have a C6 on all of his engines.
I run a C6 in my truck, I gave the ol 3spd st. drv. a toss. Damn a full size Ford truck that can't shift it's own gears is my policy.
John
John
