6.7 Powerstroke....two versions to be produced
Good article on the new 6.7 on pickuptrucks.com saying that there will be two versions of the new Powerstroke used. The higher rated engine will be used in the F-250, F-350, and F-450 pickups while a derated version with a different turbo will be used in the F-450 and F-550 Chassis-cabs. The article still doesn't give any specific numbers yet though.
Ford and the Case of the Case of the Missing Compressor - PickupTrucks.com News
Yeah, you're right but it's derated via the engine program / electronics. The 6.7 appears to be derated through the use of a completely different turbo for the chassis-cabs. It may be that it's electonically limited also.
Good point, Powerstroke72. Also, if I remember right, the pre-2010 MaxxForce 7 engines use a single borg-warner turbo and have less than 300 horsepower. Seems that when they put an engine into a heavier platform they aren't willing to warrant it for as much power due to the increased stress.
Tom, I think you're right about the Max-Force too. All of the engines like it that I've seen used in heavier applications have been derated in some form or fashion. A lot of the time too, I've seen them putting out lower HP ratings while sometimes putting out higher TQ ratings. Either way, the argument I've always heard attributed it to longevity of the engine under more stressful applications.
The other thing that sticks out in my mind also, is that most of these medium duty trucks also have much steeper gear ratios in the differentials.
powerstroke72
6.7L Power Stroke Diesel
27
02-12-2013 05:29 PM
powerstroke72
1999 to 2016 Super Duty
16
12-09-2009 09:00 PM
