catalytic converter/cherry bomb
Old 11-22-2009, 08:07 AM
tkeduck's Avatar
tkeduck
tkeduck is offline
I have a 1990 F150, 5.8L, 351W, two wheel drive, extended cab, long bed. Does anybody know if the catalytic converter is filled with the ceramic beads or the honeycomb?
I put a cherry bomb on it (single exhaust) and it is not loud at all. In fact I ran it with just the CAT and it seemed to muffle the sound better than my muffler did. The cherry bomb I have is 22" and is straight through pipe, I assumed it could be mounted in either direction as there was no airflow arrow. If I left the CAT alone will that cherry bomb ever burn out or get louder? Is there a trick to burning it out faster?
Old 11-22-2009, 08:30 AM
jplinville's Avatar
jplinville
jplinville is offline
just driving it for about 1000 miles or so should blow the packing out. As for installing it backwards, it's impossible on those.
Old 11-22-2009, 10:43 AM
zxwut?'s Avatar
zxwut?
zxwut? is offline
You could just leave it alone and not be obnoxious. I'm still trying to save up the money to fix the exhaust that the PO ****ered up.
Old 11-22-2009, 01:03 PM
tkeduck's Avatar
tkeduck
tkeduck is offline
And your Hayabusa is as quiet as a buick? Give me a break. I guess I should have specified I am not looking to wake the dead. That is why I left the CAT in place and it is only a single exhaust. This is a farm truck used for pulling. I just want to be able to hear the engine working under pressure.
Old 11-22-2009, 01:12 PM
zxwut?'s Avatar
zxwut?
zxwut? is offline
Fair enough! And actually, my Hayabusa is pretty quiet. When I was shopping for a performance exhaust, I purchased a model from Yoshimura that was fairly quiet and then got them to add an additional silencer to it. I don't need the extra attention from the po po and I also hate listening to noisy exhausts.
Old 11-22-2009, 03:45 PM
97FRD1TN's Avatar
97FRD1TN
97FRD1TN is offline
I don't know how loud you want,but your truck has 2 converters and even with a cherry bomb it's not gonna be that aggressive sounding or loud.Your best bet is to take the cherry bomb off or get rid of the converters and put on a high flow one or just get rid of them all together.But like I said it all depends on how loud you like your exhaust.
Old 11-22-2009, 07:04 PM
TexasGuy001's Avatar
TexasGuy001
TexasGuy001 is offline
I would run a high flow convertor or just the front convertor and the cherry bomb.
Old 11-22-2009, 09:06 PM
tkeduck's Avatar
tkeduck
tkeduck is offline
I know beggers can't be choosers but if I cut the second converter out is there a O2 sensor in it and if so can it be bypassed or re-mounted so as an error code does not pop up?
Old 11-22-2009, 09:16 PM
97FRD1TN's Avatar
97FRD1TN
97FRD1TN is offline
the o2 sensor is upstream of the converters,so you will be fine.
78cowboy
13
08-26-2013 10:18 AM
Filthy1955F100
08-07-2013 06:16 PM
TractorMaster96
01-27-2013 10:40 PM
70torino429
04-18-2010 12:01 PM
89broncobob
1978 - 1996 Big Bronco
09-18-2003 03:15 AM
Quick Reply: catalytic converter/cherry bomb
