engine size? - Ford Truck Enthusiasts Forums
engine size?
Old 11-22-2009, 02:56 AM
ktm747 ktm747 is offline
ktm747 is starting off with a positive reputation.
engine size?
is the size of the engine stamped into the block? if so where is it
Old 11-22-2009, 05:06 AM
jowilker's Avatar
jowilker jowilker is offline
jowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to behold
No it is not. If you are referring to the 352 on the FE block it is a foundry stamp in the mold of all of the FEs.
John
Old 11-22-2009, 07:39 AM
67nukeford's Avatar
67nukeford 67nukeford is online now
Nebraska Chapter LDR
67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation
And if it's stamped with that 352 stamping, you'll have to measure the stroke to find out what size motor it is.
Old 11-22-2009, 01:09 PM
Fordgery's Avatar
Fordgery Fordgery is offline
Fordgery is starting off with a positive reputation.
Ford!
But, on the bright side, the distributor is on the right end of the engine! Very nice for those of us with lower back pain.
Old 11-22-2009, 07:39 PM
Manic_Mechanic68 Manic_Mechanic68 is offline
Manic_Mechanic68 is starting off with a positive reputation.
You can identify it by the vin code. If you are referring to your 1967 turck the first part of the vin will read F25 meaning that it is an F250 with 2WD F26 is an F250 with 4WD. The next letter i.d.'s the engine size which will most likely read as a "Y" which makes it a 352 if it is the stock motor.
Old 11-23-2009, 12:18 AM
DarrellJ's Avatar
DarrellJ DarrellJ is offline
DarrellJ is starting off with a positive reputation.
I think the vin is a good indication if you think the truck hasn't been messed with (or changed), but measuring stroke is a reasonably accurate determination. Obviously crank casting numbers are supposed to be the definitive measure... Check prior threads with me as author, numberdummy or instig8r63 (if I remember right) laid out the different sizes based on stroke...
darrell
Old 11-23-2009, 11:43 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Stroke: 352/360 = 3.50" // 390 = 3.78"
Old 11-30-2009, 11:58 PM
it came with a 352 but a 390 was put in it iguess thanks for the help
No injector buzz when key is turned on? reptyls 6.0L Power Stroke Diesel 2 01-25-2015 07:35 PM
HEI? jd52cranbrook 1947 and Older Ford Trucks 5 10-30-2013 07:24 PM
Check Engine Soon Light Bob Edmons New Member Introductions 3 11-05-2007 12:52 AM
2008 6.4L Crankshaft Recall mikedeason 1999 to 2016 Super Duty 11 04-02-2007 11:38 AM
Trannys? DANDEE1996 Flathead V8 & Flathead 6 5 01-17-2006 05:18 PM
Tags
100, 1967, 2008, 67, engine, f100, f250, ford, motor, older, size, sizes, truck, trucks, vin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
