Fuel bowl drain valve
Old 11-21-2009, 12:55 PM
5280's Avatar
5280
5280 is offline
Well I finally replaced the fuel bowl drain valve o-rings. Being a diesel noob I was a little apprehensive about doing this, but all went well. I used the blue o-rings from diesel o-rings.com, I managed not to break anything, only skinned one knuckle and no leaks! The engine valley was full of fuel and the area around the valve was wet, I'm glad I finally did this. No more raw fuel smell at idle now
Old 11-21-2009, 06:28 PM
crazymut's Avatar
crazymut
crazymut is offline
Good job on jumping in and doing it yourself. Welcome to the club. Stick around here and you will be doing lots more. And then you will start PMSing. Powerstroke Mod Syndrome.
Old 11-21-2009, 06:58 PM
F350-6's Avatar
F350-6
F350-6 is offline
Congrats on a job well done. You've found a great resource here at FTE. Don't be afraid to ask questions and you'll be amazed at what you can do.
Now just sit back and think about how a mechanic or dealer would have replaced the entire drain assembly and charged you at least a couple of hundred dollars and kept the truck who knows how long. Think of all the guys out there who are paying to have this repair done, and suddenly you're not such a noob anymore.
stevestroke01
01-05-2015 07:15 AM
5280
05-04-2014 09:30 PM
SuperDutyScaler
04-26-2013 05:54 PM
bigtexan99
18
01-07-2013 12:30 PM
ron's power stroke
20
12-08-2011 02:11 PM
Quick Reply: Fuel bowl drain valve
