F250 5.4 3 valve How well does it pull with 3.73 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 11-21-2009, 09:49 AM
ArnoldSmith ArnoldSmith is offline
ArnoldSmith is starting off with a positive reputation.
Need to pull 5th wheel with wt of 7,500-8,500 - What fuel mileage to expect? Any comparisons with Chev 6.0 2500?
Old 11-21-2009, 09:53 AM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
I had one. It was a 06 F250. I bumper pulled a TT with it. It did the job pretty good. Does love the RPMS though. I would assume the same for the Chevy though. MPG's will only be around 8-9 though.
your biggest difference between the two though is gonna be the platform for towing. Ford is designed for it. Heavier suspension Trans, integrated trailer brake controller.
Old 11-21-2009, 10:38 AM
mlminor mlminor is offline
mlminor is starting off with a positive reputation.
I've got a 2008 5.4/3.73 CC 4WD with the TS auto..
I don't tow quite that much, usually around 6k-6.5k bumper pull enclosed trailer (some aero drag as well). Mine is not broken in good yet (only 5k miles), but averages: 9-10 mpg towing 6.5K enclosed trailer; with family/gear/dirt bikes light load 15-16 mpg highway; 12-13 mpg in town. If you can find a 4.10/4.30 it should give a little extra grunt with little/no fuel penalty. I think the 4.30 has a larger ring gear, but it's all overkill anyway.
I'm happy with the power, but it does rev/downshift a bit on steep grades. It maintains speed pretty well though, it's not like a '60 VW bus up a mountain! The TS tranny does a great job of putting the engine in the proper rpm for the condition at hand. I'm usually a manual transmission guy, but I found a great deal on my leftover '08 this spring and got the auto - it's much better than I expected.
The chassis is an absolute tank - I think it's basically a 1 ton. Chevy and Dodge don't really compare to the overall chassis package. It's quieter on the road than both of my cars, a bit more bouncy of course. I love this truck and glad I didn't settle for a half ton.
Old 11-21-2009, 12:15 PM
jac08f250's Avatar
jac08f250 jac08f250 is offline
jac08f250 is starting off with a positive reputation.
I have a 2008 f-250 5.4 CC 4X4 and I towed about 9500lbs and I avg about 8-9 mpg. I towed that for about 500 miles.
Old 11-21-2009, 06:15 PM
racinghoss's Avatar
racinghoss racinghoss is offline
racinghoss is starting off with a positive reputation.
I tow a 5th wheel at about 7500 pounds and I get 5-7 in the hills and 8-9 on flat roads. It tows the trailer fine.
Old 11-21-2009, 07:39 PM
redford's Avatar
redford redford is offline
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
I pull a 28 foot enclosed car hauler (when home anyway). I have an '07 5.4L with 3.73 gears.
i don't have any problem pulling midwest grades or getting up to highway speed.
When pulling I usually get around 10 MPG, but that depends a lot on aerodynamics.
Old 11-21-2009, 10:00 PM
chazworth chazworth is offline
chazworth is starting off with a positive reputation.
5.4 & 3.73
I tow a fifth wheel that is 8k dry and 9.2k to 9.5k loaded to camp. We have towed and camped 4 times since buying the camper. The combo does make you wish for more power in the hills, but on fairly flat ground it tows mine great. The engine really has to rev to maintain 65mph on a long incline, but this engine is made to do just that. I average around 7 to 7.5 mpg towing my 5'er and 14.7 to 15 on my daily commute to work.
Old 11-22-2009, 04:10 AM
redford's Avatar
One thing I discovered is that if I leave my bed cover in place when I tow, my mileage does drop to 7-8 MPG and the trailer feels 5000 pounds heavier and nervous. If I remove the bed cover, the trailer feels lighter (even though it isn't) and my mileage comes up to around 10 MPG.
Like I said, aerodynamics has a lot to do with it.
Old 11-22-2009, 05:05 AM
radium radium is offline
radium is gaining momentum as a positive member of FTE.radium is gaining momentum as a positive member of FTE.
On conventional towing my 2010 F350 5.4 4.10 pulls close to 10,200 pounds up the mountains twice a year 60 hp tractor loader backhoe and grapple on trailer to my cousins house in speculator 30 miles of the trip are up a steep grade the engine revs high but it maintains a 65 to 70 no problems at all mileages around 10 miles a gallon until that steep grade then it's probably about 6, but what would you expect I came from an F150 5.4 4.10 which used to pull the same trailer and it sure scared the hell out of me going up and coming down that hill would push you right off the road or so it felt used to get anxiety thinking about the trip now it's fun :-) don't even know it's back there oh by the way I didn't have the backhoe unit on during the F150 trips which saved about 2000 pounds. I've owned a few different brand trucks with 3.73's I can't imagine it would be that much of a difference, the super duties are perfect at towing due to their size and steering components, brake systems, transmission is incredible I've had Chevys and dodges transmissions no comparison, the Ford blows them away I agree with everyone else the transmission just finds the perfect spot and never lets you down you won't regret it take care
Old 11-22-2009, 03:51 PM
diesel-man1 diesel-man1 is offline
diesel-man1 is starting off with a positive reputation.
Wow that kind of mileage pulling a trailer. I just bought an 05 CC S/D 5.4, auto, 4.10's lift kit w/ 35's and got 11.1 empty going from Kenai Peninsula to Anchorage some flat driving and some mountains and driving sensibly!
Old 05-15-2014, 07:59 AM
glynf250 glynf250 is offline
glynf250 is starting off with a positive reputation.
Question Help
Want some advise from actual users of Chips and or throttle body mods etc....2010 F250 5.4. 4x4 want some more HP to tow with
Old 05-15-2014, 08:53 AM
Kdr358's Avatar
Kdr358 Kdr358 is offline
Kdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to behold
Quote:
Gears is the only way to get a 5.4 to get up and go while towing. Tuning won't do much, you need to get the load moving first
This thread is also from 2009...
3.73 Vs 3.55 help deciding Feldy 2009 - 2014 F150 22 04-30-2013 07:01 AM
3.73 vs 4.30 PhuzzNutz 6.7L Power Stroke Diesel 11 02-26-2013 10:01 AM
"Barn Find" 1943 Ford G8T 1.5 Ton Military rwhite07PSD 1947 and Older Ford Trucks 4 05-10-2009 12:10 PM
500th post Fullcrew7.3 Manitoba / Saskatchewan Chapter 14 05-07-2006 09:16 AM
Towing camper with F-150 cdj Conventional (Bumper Pull) Towing; Travel Trailers, Pop-ups & Slide-in Campers 3 07-15-2004 07:35 AM
Tags
05, 54, 7500, f250, ford, good, milage, mpg, o4, pull, pulling, tow, trailer, v8, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
