rough idle
Old 11-20-2009, 11:29 AM
northernlights's Avatar
northernlights
northernlights is offline
rough idle
I have a 92 7.3 idi and just got done changing out the glow plugs, I had to break loose the injecter lines do I need to bleed them the truck is idling rough now.
Thanks Craig
Old 11-20-2009, 02:14 PM
The_Josh_Bear's Avatar
The_Josh_Bear
The_Josh_Bear is offline
If your truck is running at all then you don't need to bleed anything, just make sure all of the lines got tightened back up again and none of the lines are leaking fuel.
Make sure that your glow plugs are all tightened down as well, if it was running good before it should be running well now...
The only thing I can think is that you got some bad glow plugs, which I read is not uncommon. You can do an ohm test on them, if they read 000 they are bad(engine off, wire unplugged, measure at the terminal where the wire connects). Should read 5-ish ohms if good, which is close to 000's if you have an analog meter, so use a digital if possible.
Perhaps all new/good glow plugs change the timing of the engine slightly? Help here, anyone?
I know that the glow plugs help to complete the fuel burn, so bad ones might change the timing slightly, as well as having all new ones...
Old 11-20-2009, 05:24 PM
PLC7.3's Avatar
PLC7.3
PLC7.3 is offline
GP torque is only 12 ft lbs or 1/12 of a turn after bottoming.
Injection line torque is 20 ft/lbs........
Glow plugs have nothing to do with timing......injectors would though.
Have you driven the truck since the GP replacement, could have knocked some carbon loose and it MAY be stuck on a valve lip.
Old 11-20-2009, 06:16 PM
Mat J's Avatar
Mat J
Mat J is offline
check your return lines maybe something is leaking
Old 11-20-2009, 09:52 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Dave Sponaugle is offline
I say drive it a mile or so.
You probably have a little air in the fuel supply.
So run it enough to work the air out.
Birdman_7137
06-06-2013 04:29 PM
craig4937
2004 - 2008 F150
03-26-2010 06:11 PM
Craig64
01-17-2008 04:51 AM
doocat
10-29-2007 08:59 PM
cferris
1997-2006 Expedition & Navigator
07-31-2002 11:15 AM
Quick Reply: rough idle
