Fuel Bowl Drain Valve - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 11-19-2009, 08:41 PM
RedBoat's Avatar
RedBoat RedBoat is offline
Rather Be Floatin
RedBoat is a splendid one to beholdRedBoat is a splendid one to beholdRedBoat is a splendid one to beholdRedBoat is a splendid one to beholdRedBoat is a splendid one to beholdRedBoat is a splendid one to beholdRedBoat is a splendid one to behold
Cool Fuel Bowl Drain Valve
Well I started getting the faint smell of raw diesel in the cab of the truck so I looked under the hood and the valley had raw diesel in it. 2 years ago I ordered the o-rings from Guzzle for just this occasion.
I removed the valve and replaced the o-rings, I have the type of valve that the middle comes out of so I also replaced the small o-ring on the shaft. After the reinstall I clicked the key on and opened the valve and fuel started spraying out of the top of the valve, turned the valve off and no leaks. I removed the valve again and replced the shaft o-ring again and the same thing happened again. I dont have any leaks from the valve unless I put it in the drain position with the key turned on. I guess this means I need a new drain valve?????
Should I replace it even if it only leaks when I put it in the drain position??
Old 11-19-2009, 08:54 PM
Orezona's Avatar
Orezona Orezona is offline
Orezona has a great reputation on FTE.Orezona has a great reputation on FTE.Orezona has a great reputation on FTE.Orezona has a great reputation on FTE.Orezona has a great reputation on FTE.
Or delete the bowl I don't miss mine. Makes for a better view of the Adrenaline
Sorry, no help.
Old 11-19-2009, 08:57 PM
maevans's Avatar
maevans maevans is offline
maevans has much to be proud ofmaevans has much to be proud ofmaevans has much to be proud ofmaevans has much to be proud ofmaevans has much to be proud ofmaevans has much to be proud ofmaevans has much to be proud ofmaevans has much to be proud of
I'm thinking you may have the valve in wrong, try to rotate 90 degs.
I had the same problem.
Also check for a crack on the yellow lever.
Old 11-19-2009, 09:20 PM
F250_'s Avatar
F250_ F250_ is online now
F250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputation
The only trouble I had was that I forgot to insert the lever into the notch on top of the housing body before tightening the screws around the valve body... hence I'm running with the valve closed adn no handle until I get the time to remove the valve again to reinstall the handle (unless I remove the filter housing altogether before then).
Old 11-19-2009, 10:02 PM
RedBoat's Avatar
Rather Be Floatin
How can something so simple turn into such a PITA!!!
Old 11-19-2009, 10:06 PM
F250_'s Avatar
Makes you want to delete that little sucker altogether, doesn't it!!
Old 11-19-2009, 10:20 PM
RedBoat's Avatar
Rather Be Floatin
Sure does, I really like Orezonas advice!
Old 11-19-2009, 10:21 PM
Orezona's Avatar
Quote:
I was happy enough to be done with that damn bowl, I gave it away.
Old 11-19-2009, 10:25 PM
guzzle92's Avatar
guzzle92 guzzle92 is offline
guzzle92 is a name known to allguzzle92 is a name known to allguzzle92 is a name known to allguzzle92 is a name known to allguzzle92 is a name known to allguzzle92 is a name known to all
I would say that you didn't rotate the valve shaft so the round part of the shaft is facing the o-rings, not the flat part. I doubt if there is anything wrong with your valve.
Old 11-19-2009, 10:30 PM
RedBoat's Avatar
Rather Be Floatin
Thanks Tom, guess I need to pull it again tomorrow! Third time is a charm right?
Old 11-20-2009, 12:02 AM
WA.Ranger's Avatar
WA.Ranger WA.Ranger is offline
WA.Ranger is a name known to allWA.Ranger is a name known to allWA.Ranger is a name known to allWA.Ranger is a name known to allWA.Ranger is a name known to allWA.Ranger is a name known to all
I just did mine a few weeks ago and did this very thing Pete. LOL I bit the bullet and fixxed it right then though. Got to love Guzzles Military Approved O-rings!
Old 11-20-2009, 08:12 AM
Old and Busted's Avatar
Old and Busted Old and Busted is offline
Old and Busted is starting off with a positive reputation.
I did mine a week ago after getting the o-rings from Guzzle. His step by step directions made it a breeze. Big thanks!
Old 11-20-2009, 11:07 AM
bdrummonds's Avatar
bdrummonds bdrummonds is offline
bdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud of
Quote:
Been there, done that, and dont miss it at all. Spin on filters are cheaper too.
Old 11-20-2009, 03:28 PM
superduty4x4's Avatar
superduty4x4 superduty4x4 is offline
superduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud of
I had the opposite problem last weekend, my drain valve wouldn't drain at all. Seems I got a little piece of mud jammed in the tube while elk hunting, I had to ream it out with some wire and open the drain with the key on to blast the blockage out.
got a little hard start after fuel bowl repair. carl2591 1999 - 2003 7.3L Power Stroke Diesel 1 12-08-2014 08:02 PM
Fuel filter drain valve question?? twom7 1999 - 2003 7.3L Power Stroke Diesel 17 10-10-2012 03:22 PM
Fuel drain valve o-rings size? Milwaukee1979F150 1999 - 2003 7.3L Power Stroke Diesel 4 01-16-2012 11:36 PM
procrastination, It Will bite you in the ass... sand_fiend 1999 - 2003 7.3L Power Stroke Diesel 7 10-22-2011 12:14 AM
Fuel bowl drain valve 5280 1999 - 2003 7.3L Power Stroke Diesel 2 11-21-2009 07:58 PM
Tags
2003, 73, 73l, bowl, change, diesel, drain, f250, ford, fuel, kit, problems, smell, valve, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
