F250 UBOLTS SAME AS F350 ?? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 11-19-2009, 06:47 PM
joe chevy's Avatar
joe chevy joe chevy is offline
joe chevy is gaining momentum as a positive member of FTE.
ups came today w my new F350 blocks and ubolts
to swap out my F250 blocks but i was surprised to see the u-bolts are the same length i assumed they would be longer
now just placing new blocks next to old and eyeballin it appears
ill be just threading the nut on enough to grab all the thread of the nut but no more
to those who have done this swap before
are new u bolts supposed to be longer?
im thinking ahead what if i want to install add-a-leafs down the road
so are f350 ubolts longer than f250's
2004 f250 fx4 sc sb
5.4 tow pkg plow pkg (overloads)
Old 11-19-2009, 07:05 PM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
bolts should have been longer, just getting the nut on is not gonna be good enough. I would call the vendor that you bought it from and have them ship the correct ones out.
Old 11-19-2009, 07:12 PM
TexasRebel's Avatar
TexasRebel TexasRebel is offline
TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.
It depends on the configuration...
U-Bolts for a F350 SRW 4x2 will be the same as an F250 4x4 ...they both have 2" blocks
Old 11-19-2009, 11:18 PM
78bigbronco's Avatar
78bigbronco 78bigbronco is offline
78bigbronco is gaining momentum as a positive member of FTE.
Not sure if it helps but I just went out and checked mine, I have a little over an inch of thread sticking above the nut. I also have heavy service suspension and SRW if that makes any difference IDK.
Old 11-20-2009, 10:44 AM
joe chevy's Avatar
thanx for response's guys
the part# i have is N811667S436
does anyone know what part# for the longer ubolts are?
Old 11-20-2009, 11:09 AM
bpounds's Avatar
bpounds bpounds is offline
2 bit Californian
bpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputation
Suggest you email Ed Olson at Y2KFord and ask him to look up the part number. He is a sponsor here, so you can look up the link.
Old 11-20-2009, 05:01 PM
joe chevy's Avatar
Quote:
did that
the right parts are on there way now
that guys good im gonna send some reps his way
Old 11-20-2009, 06:02 PM
senix's Avatar
he is good !
2010 F350 Rear Block Ford Part Numbers? Dov 1999 to 2016 Super Duty 0 03-23-2015 05:43 PM
Help with Factory Rear Blocks 2013 BDS Kit OneSickTruck Brakes, Steering, Suspension, Tires, & Wheels 1 11-16-2014 11:36 AM
2000 U-Bolts DHamSTER 1999 - 2003 7.3L Power Stroke Diesel 8 10-09-2014 05:45 AM
F350 UBolt Sizes??? kmc0929 1999 to 2016 Super Duty 7 05-20-2013 05:11 PM
Rear u-bolt exposed thread length? JIMRSX 1999 to 2016 Super Duty 1 02-21-2007 08:03 PM
Tags
1979, 2004, 4x4, f250, f350, length, ubolt, ubolts
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
