1978 F250 Weight - Ford Truck Enthusiasts Forums
1978 F250 Weight
Old 11-18-2009, 10:04 PM
78Custom250 78Custom250 is offline
78Custom250 is starting off with a positive reputation.
Question 1978 F250 Weight
I've got a 1978 F250 regular cab, long box 4x4, 351 and I need to haul it to a different state. I need to know how much it weighs so I can size a trailer to rent.
I've searched this forum and found some info on 1978 F150s, and it was reported to be about ~4000lbs. How much more would a F250 weigh?
I need to know how much the F250 weighs, but unfortunately the truck isn't running to take it to a scale.
Any ideas or help would be appreciated!
Thanks!
Phil
Old 11-18-2009, 10:20 PM
highboy1975 highboy1975 is offline
highboy1975 is starting off with a positive reputation.
ive seen this posted several times. im pretty sure the general ruling was around 5800lbs. not sure, but i know ive seen it on here before.
Old 11-18-2009, 10:47 PM
DL1221 DL1221 is offline
DL1221 is starting off with a positive reputation.
Yup, 5800lbs is about right. Definitelly under 6000, unloaded.
I've used a 5000# capacity trailer before to move F250s arround. The only problem was the trailer sides were too narrow and even with skinny tires it just barelly fit.
Old 11-18-2009, 11:50 PM
cfrazier77 cfrazier77 is offline
cfrazier77 is starting off with a positive reputation.
I weighed my 78 F250 4x4 400 long bed reg cab the other day, I was getting a load of rock. With no occupants and a 3/4 tank of gas it was 5430. I have a truck box too filled with heavy stuff. Also, 35 tires and a spare.
Old 11-19-2009, 01:10 PM
jb10 jb10 is offline
jb10 is starting off with a positive reputation.
how about an f150 4x4 without the engine transmission and transfer case? how wide does the trailer need to be?
Old 11-19-2009, 03:52 PM
alex211's Avatar
alex211 alex211 is offline
alex211 is starting off with a positive reputation.
Mine is right around 5000.
How Much Does Your Truck Weigh ?? Paratrooper84 6.7L Power Stroke Diesel 30 02-11-2017 10:39 AM
Vehicle weight (1978 f350 long bed) rbell14 1973 - 1979 F-100 & Larger F-Series Trucks 4 09-09-2015 08:19 PM
69 F-250 CS weigh ? coloradotrk 1967 - 1972 F-100 & Larger F-Series Trucks 20 10-07-2014 06:50 PM
How remove Wiper Arm on 1978 F250? smithshaven 1973 - 1979 F-100 & Larger F-Series Trucks 4 02-27-2011 05:44 PM
1978 f150 4x4 weight? redsuperduty 1973 - 1979 F-100 & Larger F-Series Trucks 5 11-03-2009 06:01 PM
Tags
100, 1976, 1978, 1979, 34, 4x4, 78, box, f250, ford, haul, truck, weigh, weight, wieghs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
