Michigan Salt
Michigan Salt
Ok as we all know Michigan gets snow and our roads are covered with salt during the winter months. So, I was wondering how you guys(and gals if there are some) keep your trucks in the best shape during the winter months, and how to prevent the salt from deteriorating your truck? Any tips or tricks?
Personally I wash my truck once a week as long as the temp is at 32 or higher. I make sure the bottom gets a thorough washing as well. My frame shows surface rust but nothing more. Pretty good for a daily driver at 100,000 miles. I am planning on pulling the bed this year and cleaning the rust on the frame and then treating it with a rust preventer.
I was thinking about building a deal to high pressure wash the underside of my truck that i just drive over after i've hooked it up to my big power washer.
I'm not sure what kind of nozles to use yet, seeing as i want a round cone, not a flat cone.
I'll build it out of some of the black pipe stuff, put it on rollers so i can roll it around like a dolly under the truck.
was thinking about building some sorta hooked style J or some sort to wash the fenders as well, its a beotch getting the top lip of the rear fenders.
as said, keeping the salt off with a quick spray helps; as for underneath, i usually paint the underside of my truck 3 times a year.... once in the spring after a trip to the dunes to sandblast all the salt off, once mid-summer, then i -try- to get one on before salt season. i just use the .99 cent cans of flat black from wal mart; most i've used at once is 8 cans in the spring before a show, so for <$10 you cant beat it if you have a couple hours.
