Changing speakers on a 06 F-250 ext. cab
I used this info for the front on mine. Not sure about the back but I'm guessing they pop out somewhat like the front.
Door panel removal
Door panel removal
I found these instructions here from another post
Quick instructions are
Remove 2 screws holding window latch.
Pull top panel off, pull hard straight out working around the perimiter, I started at the top, worked well.
Remove the 2 push lock pins and the 2-7mm screws. For the push lock pins push the little "button" in the center in a bit, then pull them out.
lift the lower panel straight up and out.
Assembly is the reverse. <!-- / message --><!-- sig -->
stevenn1
1999 to 2016 Super Duty
19
11-15-2007 05:53 PM
pmasley
01-21-2006 12:14 PM
Saxon
07-28-2004 10:46 PM
mattf11
06-25-2003 09:58 AM
