Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 11-18-2009, 04:47 PM
jk+6 jk+6 is offline
jk+6 is starting off with a positive reputation.
Where do we find parts for our 1994 Ford F350?
Does anyone have any good places or websites to find parts for a 1994 Ford F350 diesel 7.3? It is not turbo. We are having a hell of a time finding the "fuel rack/rails" that feed fule to the injectors. I am not even sure what its exact name is. But it is the 8 leggged "spider" that feeds the fuel into the injectors. The 1 we have has cracks and is leaking fuel. We would like to repair ir but not sure exactly how. So looking to buy a new 1. We bought this truck as a project truck siting on rims with a bad tranny. We were told it recently had a rebulit motor installed but not so sure. We had to fix all the seal under the truck and rebuild the tranny. So 1 thing at a time. And the next project is the fuel lines or "rack". Any ideas?? Please help!
  #2 (permalink)
Old 11-18-2009, 06:17 PM
Copedawg's Avatar
Copedawg Copedawg is offline
Copedawg is gaining momentum as a positive member of FTE.
hey jk, like said in the other forum, I think the Ford or International stealership is the way to go on this one. I would imagine International would be cheaper. This is not my domain so hopefully some one else will chime in with something. I think this forum will help you through you project and I wish you the best of luck. Above all...have fun!!!
__________________
97 F350 7.3L Auto 4WD Crew Cab 200K (Cali model bummer). Another OFFICIAL six point slow recovery vehicle! MODS: HOOOOGA! horn, 6637, Service/Utility bed, 3" DP, Testing that Cat, 120v IDM (for now), 2 10K pots. US ARMY OAS, OJE-IFOR, SFOR,2,5, OJG-KFOR, OIF, OEF. To ALL that have served, THANK YOU!
  #3 (permalink)
Old 11-18-2009, 06:35 PM
Links56's Avatar
Links56 Links56 is offline
Links56 is starting off with a positive reputation.
I assume you are talking about the fuel lines. Take the leaking one off and take it to the local IH Dealership. If you don't want to spend the money you could braze it and put it back on. Where Is it leaking exactly? The fuel in these lines is under high pressure and would be spraying out very noticeably. It may be leaking from the seal on the supply line or return line. Can you post a picture of the "cracks"?
  #4 (permalink)
Old 11-18-2009, 07:10 PM
rupejosh's Avatar
rupejosh rupejosh is offline
1994 Ford F-250
rupejosh is starting off with a positive reputation.
rockauto.com is a good place.and if your having issues finding parts for 94 look up parts for a 93 instead because 94 was the transition year for the powerstroke.also the fuel lines from a 6.9 will be the same as well
  #5 (permalink)
Old 11-19-2009, 11:05 AM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
1997 Ford F-350
My Garage
Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all
www.mwfi.com is a good place for fuel injection parts.
The hard lines, injection lines, will crack if the vibration dampeners have been removed and not reinstalled.
The soft rubber lines between the injectors, IP and fuel filter header are return lines.
Cracks in the return lines, O rings leaking under the return tee's or cracked return tee's are much more common and cheaper to repair.
Return line kit to replace the entire return line assembly runs about 40 or 50 dollars.
Injection lines run about 50 dollars each.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #6 (permalink)
Old 11-19-2009, 05:19 PM
Copedawg's Avatar
jk, I followed you over here to make sure you were taken care of (some forums are less considerate then others) but you obviously are well taken care of here. These people really know your/their vehicles! and Dave sounds like he really knows the deal about things. Enjoy the project!
IAN
__________________
Tags
1994 , 73 , 73l , diesel , f350 , ford , fuel , header , injector , leaking , line , parts , return , truck , trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
