Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-18-2009, 02:36 PM
DND58 DND58 is offline
DND58 is starting off with a positive reputation.
EBP actuator seal
Has anyone replaced the Exhaust back pressure seal on the pedestal?
I replaced CAC boots a while back and noticed a small oil leak, appeared to be at EBP piston rod on pedestal. Have had a small drip from starter area for @ 1 yr. I use the EBPV as a brake when towing and would like to keep it. I have the TSB on this procedure, and read on guzzles site about using a brake hone.
I have not done a lot of wrenching, but am not afraid to try. I can buy a brake hone from NAPA but not sure on size or how to use. Do I use any lube? How do I know how long to apply hone? Any suggestions on where to find spring scale tester for adjusting the preload of EBP piston rod? Any other suggestions for a green shadetree guy?
Thanks again
Dean
__________________
__________________________
Dean
2002 F350 XLT/7.3L/SC/SRW/LB/3.5"DP-4"Exh/AIS/Isspro Performax Gauges/GPR LED/Zoodad
1988 F250 REG CAB 460
  #2 (permalink)
Old 11-18-2009, 03:28 PM
Izzy351's Avatar
Izzy351 Izzy351 is offline
Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of
Most of us just gut the thing. Using the EBPV as a trans brake on a stock trans is pretty hard on it, if you're towing heavy. Lighter loads probably won't hurt it too much, but I wouldn't bother. More trouble than it's worth.
__________________
  #3 (permalink)
Old 11-18-2009, 03:52 PM
Riffraff Performance's Avatar
Riffraff Performance Riffraff Performance is online now
PREMIUM SPONSOR
Riffraff Performance is a name known to all Riffraff Performance is a name known to all Riffraff Performance is a name known to all Riffraff Performance is a name known to all Riffraff Performance is a name known to all Riffraff Performance is a name known to all
If you enjoy using it I would keep it. I use mine and really like it. All you will need is a rebuild kit and a small brake hone if you have access to one. It doesn't take much at all, just a few passes. Here is a link for the IH Kit.
Riffraff Diesel: Exhaust Backpressure Valve piston rebuild kit
__________________
Clay
Parts Guy Ed - The one and only choice for OEM Parts
Tags
ebp , f250 , rod
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
