I have an 91 f150 with the automatic start and I would like to put it on my 01 Escape but I need the wiring diagram because its different between the two. Does anyone know if this will work? and any diagrams?
For starters, the Escape has PATS and the F-150 does not. You need to contact the manufacturer of the auto starter and see if it was compatible with PATS and if the PATS add on module is still avaible. They should have the wire diargrams for the module as well as simplified diagrams for the vehicle and where to tap into the wire at.
If it was a Ford module, thay were made by code alarm, and in my opinion of using 2 of them, you are better off just buying a new aftermarket one. I did that for a Blazer, and it was hassle free and had a lot farther range.
My 2003 F-250 came with a low end code alarm, and it's range is low as well.
