How hard is it to change a power steering pump? - Ford Truck Enthusiasts Forums
Old 11-17-2009, 11:36 AM
mrgn_mtt's Avatar
mrgn_mtt mrgn_mtt is offline
mrgn_mtt is starting off with a positive reputation.
Question How hard is it to change a power steering pump?
Hey my power steering pump might be on its last legs. I was jut wondering how much of a pain in the *** it would be to change it and what kind of cost i would be looking at. My truck is a 1996 F-150 2wd regular cab short bed, with the inline 6.
Old 11-17-2009, 11:40 AM
quicklook2's Avatar
quicklook2 quicklook2 is offline
quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.
mechanically inclined with correct tools and manual: easy.
good time to replace hoses.
Old 11-17-2009, 11:44 AM
jplinville's Avatar
jplinville jplinville is offline
jplinville has a very good reputation on FTE.jplinville has a very good reputation on FTE.jplinville has a very good reputation on FTE.jplinville has a very good reputation on FTE.
if you can change an alternator, a PS pump is nothing...
Old 11-17-2009, 12:33 PM
BCHauler's Avatar
BCHauler BCHauler is offline
BCHauler has a good reputation on FTE.BCHauler has a good reputation on FTE.
Good time to upgrade to the saginaw style pump. Won't cost anymore and much better.
Old 11-17-2009, 04:23 PM
jr32560's Avatar
jr32560 jr32560 is offline
jr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to behold
on my 90 I had to rent the pulley puller when I changed mine out -wasn't hard at all
oh and I had to change the connections where the hoses connected-I opted for a junk yard model -hook ups were different-leaked pretty bad till I changed out the fittings for the old ones off my original
good luck
Old 11-28-2009, 03:22 PM
neilj neilj is offline
neilj is starting off with a positive reputation.
not hard can be done with a metric set of wrenches and a pulley puller/installer mine cost about $40.00. Some pumps come with the resevoir already installed, some you have to put your old one on.
Steering column questions billhannah 1961 - 1966 F-100 & Larger F-Series Trucks 2 07-08-2014 12:25 PM
Power steering fluid alternative rews2 1967 - 1972 F-100 & Larger F-Series Trucks 5 06-03-2014 12:57 PM
Power steering pump Blackwaterforge 1961 - 1966 F-100 & Larger F-Series Trucks 4 10-25-2012 08:25 AM
Power steering pump tx fisherman 1987 - 1996 F150 & Larger F-Series Trucks 1 02-07-2011 09:25 PM
power steering pump hose replacement mazdazoomzoomtruck 1973 - 1979 F-100 & Larger F-Series Trucks 6 09-12-2010 02:53 AM
Tags
1996, 1999, 2001, 49, 4x4, change, e250, f150, f250, ford, power, pump, replace, steering, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
