302 Build for 4x4 - Ford Truck Enthusiasts Forums
302 Build for 4x4
Old 11-17-2009, 11:35 AM
zerick zerick is offline
zerick is starting off with a positive reputation.
302 Build for 4x4
Hey guys, I am going to be getting a mid 90ish ford in the next couple of weeks. I am going to get a 302 and 4X4. This truck will be my daily driver for the next couple of years, so I want to rebuild the motor. When I rebuild the motor, I want to get some more power out of it. What would you guys recommend for the build? I want more power, but I want it to work good in a four wheel drive. Would a 331 or 347 be to much for the truck, or would it be better to just bore it out and do some intake and exhaust work.
Thanks everybody
Old 11-17-2009, 03:08 PM
lew52's Avatar
lew52 lew52 is offline
lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.
Bigger is better , so a 347 would be good . Some 94 & 95-96 302s are roller mass air trucks that are better for a performance build IMO . Heads , long tube headers & exhaust ,, cam , gears , will all help , just depends on how much you want to spend .... Lew
Old 11-17-2009, 04:14 PM
Freaksh0w's Avatar
Freaksh0w Freaksh0w is offline
Freaksh0w is starting off with a positive reputation.
Yeah, depends on how much you want to spend. But the little things that will make it like a different truck would be lower gears, full exhaust, and a good torquey cam.
Old 11-17-2009, 05:34 PM
Thanks for your replies. I am looking to spend around 2 grand in the rebuild. I have found 347 stroker kits around $1000. If I went with a stroker, could i reasonably build the rest of the motor for another $1000?
What would be the best type of cam to put in with a 347 to give it good power, but at the same time not too much so it can be a reliable daily driver?
Old 11-17-2009, 05:56 PM
lew52's Avatar
Well to do a 347 right it might cost another $1000 in machine shop work . So if your on a buget rebuilding the 302 might be better . Long tube headers , something like GT 40 heads , cam will depend if is a roller or mass air motor.... Lew
Old 11-17-2009, 06:46 PM
I am going to get a 95 or 96 so that it does have MAF. How much horsepower/torque could you get out of a stock 302 that year with some head, cam, and exhaust work?
Old 11-17-2009, 06:49 PM
Kemicalburns's Avatar
Kemicalburns Kemicalburns is offline
Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.
if your looking why not find a truck with a 5.8 and start with a better platform for building power?
Old 11-17-2009, 06:55 PM
lew52's Avatar
About 300 HP - 350 TQ
Old 11-17-2009, 07:36 PM
300 Horse would be fine with me. What kind of cam would you recommend? What heads?
Old 11-18-2009, 05:18 AM
lew52's Avatar
The comp 35-349-8 has been used alot with good results , AFR heads are very good but expensive . GT 40 or GT 40p heads are easy to find & will work well , check out craigs list . Gearing is very important on the 302s so keep that in mind , depends on your tire size ..... Lew
Old 11-18-2009, 09:51 AM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Quote:
+1. For truck applications it makes no sense to build a stroker from a 302 when you can already get that displacement in another motor. Take the $$ you would spend on the stroker kit and put it into heads and intake for the 5.8 and you'll have a more powerful motor for the same money. You would have to really screw things up to get less than 350hp and 400ft/lb TQ out a built 5.8.
302 build up, need your help db619 1987 - 1996 F150 & Larger F-Series Trucks 44 09-25-2012 07:21 PM
4.6 vs. 5.4 for build ArrizX Modular V8 (4.6L, 5.4L) 4 02-26-2012 10:29 AM
my 81 f150 build jonathan734 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 05-11-2009 02:38 PM
460 build crossbeed_65 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 3 02-18-2004 09:21 PM
302 to 351w swap in a 71 F100 Rd71 1967 - 1972 F-100 & Larger F-Series Trucks 8 10-12-2002 01:14 PM
Tags
302, 4x4, 50, build, builds, ford, good, motor, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
