Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > New England Region > Massachusetts Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Massachusetts Chapter Join Chapter, Leader: donjamer
  #1 (permalink)
Old 11-17-2009, 10:24 AM
barecove's Avatar
barecove barecove is offline
2004 Ford F-150
barecove is gaining momentum as a positive member of FTE.barecove is gaining momentum as a positive member of FTE.
HELP w/noise from front end
it is an odd bearing like noise... happens when I am at speed and need to accelerate to pass or on an incline.... once I stop accelerating it stops... it does not change with the speed but stays constant... I was told to check the cv half shaft.... anyone experience anything like this or have any thoughts about it ??
__________________
"Make way for the positive day" ... Steve
2004 F150 XLT w/AEM CAI and Magnaflow Exhaust
Nitto Terra Grappler Tires mounted on 18" Hela Black Spoke Rims w/ Machined Lip , Nasta Billet Grill
Ma.,
N.H. & Mid Atlantic Member
  #2 (permalink)
Old 11-17-2009, 05:16 PM
BIGKEN's Avatar
BIGKEN BIGKEN is offline
So Little To Say!!!
Garage is empty, add now
BIGKEN has a superb reputationBIGKEN has a superb reputationBIGKEN has a superb reputationBIGKEN has a superb reputationBIGKEN has a superb reputationBIGKEN has a superb reputationBIGKEN has a superb reputationBIGKEN has a superb reputationBIGKEN has a superb reputationBIGKEN has a superb reputationBIGKEN has a superb reputation
Steve...I'll check with a couple of our techs in the morning and see what they think.
__________________
Member of the Massachusetts Chapter and Number One Winter Hater!!!
Illegitimi non carborundum!!!
  #3 (permalink)
Old 11-17-2009, 11:04 PM
barecove's Avatar
2004 Ford F-150
muchos gracias big guy.....
__________________
Ma.,
  #4 (permalink)
Old 11-19-2009, 02:52 PM
BIGKEN's Avatar
So Little To Say!!!
Steverino...sorry about the delay in getting back to you...been very busy at the rockpile...and...the FTE Gremlins have been pi$$ing me off.
I talked to two of our Ford techs...independently...and...they came up with the same thought. They both think that your problem isn't in the front end...it's...ahem...with your REAR end!!!
They both think that your problem is most likely a bad ring/pinion gear.
Hope this helps!!!
__________________
  #5 (permalink)
Old 11-19-2009, 08:59 PM
donjamer's Avatar
donjamer donjamer is offline
2006 Ford F-350
donjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputation
Steve,
Not sure about the noise, but on my 99 F350 it had a noise that the Ford tech said was in the rear end.. I checked it out and found the Carrier bearing one the drive shaft was gone.. Price to fix was $125 VS over 1K for the rear end work..
Not sure if your truck has the bearing on the drive shaft, but I would check all the ujoints for play..
__________________
Don #3 SlackMaster
Chapter Leader of the Massachusetts Chapter
Join the MA Chapter Here
Currently own:
2006 F350 Lariat CC Super Duty, 6.0 L Diesel
FTE Fraternity OF Blue Max
  #6 (permalink)
Old 11-20-2009, 12:50 PM
barecove's Avatar
2004 Ford F-150
I'll be a monkey's uncle if the noise is coming from my rear end... but hey, stranger things have happened..... as far as the u-joints.... this doesn't sound like any u-joint I have heard before.... again, I will check to make sure....
__________________
Ma.,
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
