driprail and roof rust replacement schematic.
Hmm, Interesting. I've been around a lot of these trucks and I've only seen one rusted there. It was on a red & silver truck where the silver wears away so it was down to bare metal.
Is this is bigger problem then what I've personally seen? Where you are saying the rust starts, whats the best way to rust proof that area? Just pull the head liner?
on
Pull the headliner, spray Heavy duty anti rust, por 15 or what ever you can get in there.
on
post some pics, maybe i can advise on your super cab.
Supercabs seem to have a problem with rusting the vertical part of the driprails. I would use a spotweld cutter and remove that section if it is bad as removing the roof for those sections is not necessary. Or if it looks solid enough, clean the area up with a brush attachment on an angle grinder (delicatly), then treat the area with rust converter, getting it in the seams. If the horizontal part is bad, refer to the schematic.
If you have rust all of the way around, I don't see what other choice you have. If its just a small area, just replace that spot. Avoid making butt-welds on the 73-up roof skin as it is very difficult even for a professional to do on the thinner metal. (that is why replacing the whole roof is likely faster and easier than fixing your old one)
As there is no other rust anywhere else on the truck I started thinking that water may be entering through the old dried out cab light seals and running back.
It's possible. My truck (regular cab) was sold new in FL and stayed there for quite a while. I have major rust on and under the drip rails, but the rest is solid. It's baffling.
