Injecotr seals
Injecotr seals
Hi,
I am still a 6.9 (86 model, but has 87 glow plugs) newbie, and having some issues with leaking injectors.
I've been to Autozone, Oreilleys, Napa, and nobody has an injector seal kit, but they only have a "return line" kit, but no pictures of orings in the kits.
Yes, Viton, but where do you find them? What are the part numbers?
Thanks,
Glen
Thanks,
Glen
None of the kits I know of have viton seals in them, it's really unnecessary and someone on here commented they are stiffer and do not seal as readily as the regular Buna-N seals. I bought the 1/4" fuel line from Napa, and got the o-rings from Tractor supply. The o-rings are standard, so if you want to use viton, you can go to a industrial supply place like McMaster Carr online and order them. I will see if I can dig up the o-ring size. The ones I used from tractor supply were made for hydraulic fittings, but they are the same Buna-N material.
