Help replacing U joint in TTB
I did this when I replaced ball joints on my '91. (only did left side- now RH balljoints are loose- DOH!)
Take out lockout and spindle nut(s)* and then remove the hub / rotor assy.
Then you will have to unbolt the inner hub (has 6 bolts that hold it to the spindle) and then the axle shaft simply slides out.
Be sure to inspect wheel bearings and repack with fresh grease.
If theres an easier way, somebody let me know. I need to replace a joint on my F250.
* You will need a special socket
I found this, looks to be a solid axle D44, but i think it should be the same though right?
Dana 44 Front Axle Shaft U-joint Replacement .: Articles
Can sombody scan and post the TTB exploded view? Im having trouble trying to get the hub off. I have the lock nut out, and C clip and the washers after that. ALso i pulled the other half washer that slides back into another bearing i belive. I cant tell if im forgetting something.
Thanks.
Thanks.
Kyle Sherman
03-29-2017 03:26 PM
ctubutis
02-08-2011 09:14 PM
strokersace
12-29-2010 11:22 PM
86bigred
09-30-2009 10:18 AM
