rear brakes dragging
Hello to all,
I have searched here before and found my answere, but this time not so much.
I Have a 2001 f250 supper duty 7.3. I have replace both rotors calipers pads and rubber hoses for the rear. And my rear brakes will still intermitantly began to drag. I now have the main brake line disconected at the rearend, and no fluid is dripping out. I have bleed brakes on many vehicals including this one using the gravity method and never have I seen no fluid dripping from a breeched brake system... Any thoughts
Layson probably has your answer about the brakes seizing up, but that doesn't answer the no brake fluid problem.
As for finding the fluid, I would get a second person and use the 2 guy system, one working the pedal, and one loosening the line or bleed screw. If that's not an option, then start loosening the brake line at the master cylinder and start your way back till you come to a place with no fluid. If all is working well, you should be able to open the bleed screws and open the reservoir and have all kinds of fluid running.
I put all these new parts in just a few days ago, and I don't want to cook them. I have learned of "brake pedal kickback". Aparently it is caused by contamination in the power steering system. Yes I was one of those who thought power steering used power steering fluid. Tomorrow I will be purging my pump with ATF. leaning towards ABS, but the front is not affected at all. So maybe MC...
https://www.ford-trucks.com/forums/8...ing-flush.html
Where are my manors, hotwtr, welcome to FTE!
Check out the thread I posted here and follow redboat's first post.
on
On the photos... If the photos are stored in your computer, just click on reply or "go Advance" and then click on the "paperclip icon" in the task bar above the reply block..Browse to find your photos and attach your photos an attachment...
Guille625ram
1999 to 2016 Super Duty
09-02-2016 03:00 PM
ManfredVonRichtofen
1978 - 1996 Big Bronco
05-13-2016 10:28 PM
mxhowes1
19
01-07-2016 11:38 AM
rookiemistake
15
12-09-2015 10:01 AM
