Mazda R2 to ZF S5-42 - Ford Truck Enthusiasts Forums
Old 11-16-2009, 09:31 AM
TheWhiteBeast TheWhiteBeast is offline
TheWhiteBeast is gaining momentum as a positive member of FTE.
I have a 1988 F-250 that came from the dealer as a light duty with a 5.0L. After about 280,000 miles the motor decided to take a giant dump, so I bought a used 5.8L with roughly 70,000 on the clock. The issue I am running into is that the Mazda R2 just doesn't seem to hold up to the 5.8L. Is there any trouble doing the swap? Do I need a shorter/longer drive shaft. Also, it is a 4WD, do I need a different transfer case? Any help would be greatly appreciated
Old 11-16-2009, 01:41 PM
andym's Avatar
andym andym is online now
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
A couple people have done the swap. I believe the driveshafts are the same length, the swap is pretty much a bolt-in. There are a couple threads in here about this swap.
Old 11-17-2009, 12:02 AM
9.ford.5's Avatar
9.ford.5 9.ford.5 is offline
9.ford.5 is gaining momentum as a positive member of FTE.9.ford.5 is gaining momentum as a positive member of FTE.
mazda 5 speed to zf 5 speed is a direct bolt up...just make sure you get the right zf
since you have 4wd you need to find a 4wd zf, the 2wd version has a fixed output yoke and no mounting options for the t-case, they have a totaly different tail housing...but the 4wd zf will bolt up with your t-case, many of them came with your t-case
tranny x-member and mounts and drive shafts are all the same
you gotta watch out for the bellhousing pattern though, there are 2 or 3 different patterns on the zf (small blocks, diesels, and possibly one for big blocks too but they might be same as the diesels)...if you have the winsor you can use any zf thats behind a 300/302/351w
also the diesel zfs have a close ratio gassers have a wide ratio...i think thats the way that goes...but it doesnt matter cause a diesel zf wont bolt up to your 351 any way
good luck...i have been searcing for one to put in my 95 for months with no luck...
P.S. the tranny code on the door sticker is "2" for the tranny you want
Old 11-17-2009, 05:39 PM
Pkupman82's Avatar
Pkupman82 Pkupman82 is offline
Pkupman82 has a good reputation on FTE.Pkupman82 has a good reputation on FTE.
Indeed it is a bolt in swap, I broke the Mazda trans in my 96 F150. I don't think the M5R2 will hold up to much more than a 2.3 can put out, I broke mine with a 300 six! I added mine as part of a 4wd conversion, it bolted right up... same clutch, slave cylinder, reverse light switch, trans mount, and the t-case bolts right up too. I didn't get so lucky on driveshafts, but that was because I going from a 2wd to a 4wd set up.
Old 11-18-2009, 01:14 AM
9.ford.5's Avatar
Quote:
Originally Posted by Pkupman82 View Post
I broke mine with a 300 six!.
you say that like you are surprised...
the M5OD should never have been behind the 300, that engine puts out too much low RPM torque for that tranny and everyone i know with this setup tears that tranny apart, unless the truck never works and is a complete pavement pounder, which is rare for that setup...my 300 has killed its M5OD too, looking for a zf, 300 I6 and zf 5 speed is the only way to go!
Old 11-18-2009, 02:27 AM
Pkupman82's Avatar
I'm actually not surprised that I broke it with my 300. I am no stranger to the 300s low end torque and stubborn reliability. A number of people I talk to are surprised a 300 can break anything... I guess they never had one before! I have broken motor and tranny mounts, among other things with my 300, again not really surprising to me.
I absolutely love having a ZF behind the 300, you get the best of both worlds. A nice deep first gear for crawling, wheeling, and pulling, and a .76 overdrive gear for cruising down the highway; all in a nice tough package.
Old 01-15-2010, 06:31 AM
southernchaos southernchaos is offline
southernchaos is starting off with a positive reputation.
wow sweet reading this answered nearley every one of my questions lol what about drive shafts thoug will the factory 4x4 shafts work when swapping from a m5r2 to a zf?
Old 03-06-2010, 05:31 PM
Scrambler81 Scrambler81 is offline
Scrambler81 is starting off with a positive reputation.
I have a 95 F150 5.0l, 5 speed, 4x4. My M5R2 died on me and I was going to swap it out with a ZF S542. Will my slave cylinder, clutch, cross member, transfer case (bog warner1536),and drive shafts work with this swap. What kind of problems will I run into, and will this swap work with my truck?
Old 03-06-2010, 05:57 PM
ya the swap will work with all the componets you already have with the exception of the driveshafts im not sure on those
Old 03-06-2010, 06:40 PM
Cool thanks for answering that I talked to Jasper engines and a few mechanics and they were no help at all.
Old 03-06-2010, 07:17 PM
they normally arent because they want to work on the truck themselves so they can charge you a arm and leg for labor
Old 03-06-2010, 09:29 PM
DJdemon6696 DJdemon6696 is offline
DJdemon6696 is starting off with a positive reputation.
am i the lucky one that the M5OD didnt blew up yet behind my 300 ftlbs 302 ???
Old 03-06-2010, 11:36 PM
naw i have a m50d in my daily driver behind a 5.8 but the truck isnt ever driven hard so i guess that really doesnt count
Old 03-27-2010, 11:09 PM
Quote:
The driveshafts work just fine. Thanks again.
Old 03-28-2010, 12:12 AM
fordman1090 fordman1090 is offline
fordman1090 is starting off with a positive reputation.
my 300 killed my M5OD on Friday. All the sudden the shifter went to mush, When its in gear the shifter moves around like its in nuetral, Its still drivable but make interesting noises if the shifter isnt in the right place, and i have this airy feeling that all the sudden there's going to be a loud "BANG" and pieces of aluminum, hardened steel and tranny fluid will be scattered about the roadway.
Good thing there is a ZF in the garage im getting prepared to swap in
problem with ecu pls help z21Gameplay Escape & Escape Hybrid 1 01-22-2016 07:43 AM
M5od replacement Willz74 1987 - 1996 F150 & Larger F-Series Trucks 13 10-01-2015 10:53 PM
1993 tranny questions Thedonk 1987 - 1996 F150 & Larger F-Series Trucks 3 09-11-2015 09:13 AM
94 F150 Floor shifter HootieD New Member Introductions 1 03-24-2015 04:52 PM
95 2.3l ranger into a 1988 mazda b2600 2.6l rig_pig30 Ranger & B-Series 4 08-14-2005 09:58 PM
Tags
300, 302, 5spd, bolton, direct, f150, ford, inline, m5od, mazda, r2, swap, swapping, transmission, zf, zf5
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
