5.4 to v10 swap - Ford Truck Enthusiasts Forums
Modular V10 (6.8l) SPONSORED BY:
5.4 to v10 swap
Old 11-15-2009, 08:00 PM
green250 green250 is offline
green250 is starting off with a positive reputation.
5.4 to v10 swap
Just swapped out a 2000 5.4 superduty f250 engine for a 2002 6.8 v10.Everything was pretty straight forward except for the belt pulleys.The belt from my 5.4 is too wide for the v10.I ordered an a/c delete pulley for the v10 engine and it has 7 ribs like the 5.4.Is there different size crank dampers and power steering pulleys etc.?Can i swap out the wider 7 rib pulley from my 5.4 alternator and crank damper or not?
Thanks for any advice.
Old 11-17-2009, 12:31 AM
bill11012's Avatar
bill11012 bill11012 is offline
Modular motor junkie
bill11012 has a great reputation on FTE.bill11012 has a great reputation on FTE.bill11012 has a great reputation on FTE.bill11012 has a great reputation on FTE.bill11012 has a great reputation on FTE.
You should be able to swap them ok, look for a part number on them.
Is it the same or different?
If it is the same you are good to go.
Old 11-17-2009, 12:16 PM
Krewat's Avatar
Krewat Krewat is online now
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
Did that V10 come out of a van?
There are two widths, I think 6 rib, and 8 rib. My V10 has the wider belt, and it's a 2001.
The '99's, I believe, have the 6-rib belt, in the F-series.
I wonder if the vans didn't.
Old 11-18-2009, 11:55 AM
The engine came out of a 2002 f250.A friend who works on these told me it shouldnt matter.I just used the 6 rib belt and fired it up.Everything appears to be good and the truck has a ton more power!I ran into a couple different kinks like the fan clutch being different than a 5.4 so i had to buy one from a junkyard.I also needed an intake kit so i just bought a volant instead of a stocker.The other thing i noticed is the alternator is a 2 wire on the v10 so since i had the 5.4 alternator/battery harness i had to use the 5.4 alternator but it bolted right in so no problem.Maybe a year thing instead of a 5.4/v10 thing i dont know.
Thanks for all the help guys!
Old 11-18-2009, 01:16 PM
Krewat's Avatar
Something doesn't make sense. From what I remember, the early '99's in the F-series had the 6-rib belt, while 2000-up definitely had the 8-rib belt.
But, I think the E-series has the 6-rib. Weird. Very weird.
Old 11-18-2011, 09:05 AM
stern1 stern1 is offline
stern1 is starting off with a positive reputation.
Can you email me, need to ask you some question about this swap. rubicon1272 at yahoo dot com.
Thanks
Rob
Old 02-23-2014, 10:37 PM
Mattjcott Mattjcott is offline
Mattjcott is starting off with a positive reputation.
I want to do this swap in my truck. How does the PCM work? Did you need the engine harness from v10 ?
Old 03-04-2014, 11:53 PM
OSHS OSHS is offline
OSHS is starting off with a positive reputation.
I'm curious what all you did with the engine harness, body harness and PCM.
Old 03-05-2014, 12:03 AM
To make everything work, that is. Did you simply swap everything over from the donor truck?
Belts for 300 I-6? What year do I have? 86stepsideF150 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 08-27-2016 11:39 PM
Chewing Up Belts/Water Pump Pulley Out Of Alignment - Help? Spktyr 1994.5 - 1997 7.3L Power Stroke Diesel 23 01-11-2016 02:04 PM
3v 5.4 to 3v 6.8 swap? zimm Modular V10 (6.8l) 3 06-04-2015 07:22 AM
Power Steering Pump Question Spktyr 1994.5 - 1997 7.3L Power Stroke Diesel 1 07-16-2014 10:21 AM
Crankshaft damper spacing problems cbisk Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 0 11-08-2004 02:34 PM
Tags
10, 54, 54to73, 68, belt, clutch, delete, engine, f150, f250, fan, ford, kit, rib, swap, swapping, v10, year
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
