Ford COE 196? Y-Block
Dick~
Ford did use a truck-ized version of the Lincoln Y-Block available in C-750, C-800 and C-900 models thru 1963. (Looks like the C850's came with the Super Duty engines.) The engines came in 279 and 317 from 53-55 and 302 and 332 from 56-63. A quick way to distinguish the larger Y-block is with the bolt pattern on the ram horm exh. The smaller Y-blocks were in a single plane. On the larger ones the outer most bolts on each end were canted up a bit. Also, on the larger Y-blocks the valve covers had more pronounced ridges at the bolt location. Pics below:
Badass56
04-17-2018 10:19 AM
phoneman91
37
05-23-2005 08:19 PM
darkman
12-31-2001 05:25 PM
