80/100 bulbs in factory housings?
My Raptor's lights lack umph. On a previous vehicle, an old Scout, I put in Hella housings with 80/100 halogens in it. They were amazing and negated any more lights. I think the Raptor looks awesome and don't want external light housings junking up the truck's lines so that's what I'd like to do.
I already know to power the big bulbs from the battery and use the factory wiring to run relays because the extra current is too much for the factory wiring and switches, but will the factory housings take the heat?
That has been my biggest complaint on ford trucks I've been in or owned for years. I don't understand the R&D they do and leave the headlights to suck.
That being said, try the sylvania ultras first.
OSRAM SYLVANIA - SilverStar ULTRA
Of course, they aren't street legal, can lead to you receiving a citation, and can lead to people flashing their bright lights at you... they restrict the output power of headlights for a reason. You may be able to see better, but if you blind the guy coming head-on at you at 140mph closure (70MPH * 2) on the dark two-lane road and he can't see the center line and strikes you head on, you're going to die (most likely)... your ultra-bright headlights didn't do you much good.
got flashed. After I leveled my F150 I got flashed non stop. So you can safely increase your trucks light output as long as it is properly directed.
I wouldn't bother. I tried them in my 05 SD. Made no difference. I still have the bulbs but haven't bothered to install them in my F150 yet. I did install some Acura hid projectors in my SD and they were awesome and I never
Save your money on silverstars and get philips ultra crystals instead from bulbs.com.....way better....and i've had both.
That said....i put a set of hid's in my families honda accord a few weeks ago and they're frickin amazing....no glare...and properly aimed they never get flashed for being too bright.....i'm about to get a set for my truck.... retro-solutions.com
The housings would maybe be fine, it is the connectors to and on the bulb that are for sure a problem. The 9008 bulbs have tiny terminals that will overheat fairly easily. Even upping the voltage on stock wattage bulbs (with a relay system and pulling power straight from the battery) has been known to melt the connector.
I am running the 9008 Silvania Xtravisions, they are a bit brighter than stock, but not too much. I recommend staying away from the blue tinted (even lightly tinted like the silverstars) bulbs as they tend to be terrible in the wet IMO.
Check out hidplanet. It's a site like this one but lights only.
You installed the ultra's and noticed no difference? Huh, funny, I've got two co works w/ 08 F-350 Lariats and they swapped to the Ultras and noticed a huge difference. The color difference alone adds to night visibility. Ford does need to get their headlight program on track. EVERY ford SUV / Truck I've driven has had crappy lights. I don't understand why they can't get something as simple as a headlight right. From this thread and many others I'd say I'm not alone on that statment.
