You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
289: 2 = Medium Blue Crush Vinyl & Medium Blue Match Stick Vinyl // 89 = 89A Econoline Van
C = Ford Type 3.03 3 Speed Manual all Syncromesh Transmission
07 = Ford 9" Rear Axle / 3.00-1 / Non Limited Slip / 3300 lb. Rear Axle Capacity
4930 lbs. Gross Vehicle Weight Rating
129 net HP @ 4,000 RPM.
71 = Los Angeles (SoCal) Ford District Sales Office, where the original selling dealer ordered the vehicle from.
--------------------------------------------------------------------------------------------------------- * This info is for an Econoline VAN, not for a pickup. An Econoline pickup is body style 87.
Here's why this info is in-correct: The Warranty Plate is located on the left door face. People swapped left doors due to damage with used doors.
99% of the time, they did not install the original Warranty Plate on the replaced door.
If you compare the VIN on the registration with this VIN from the Warranty Plate, you will see that they will not match.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
thanks for the info,previous damage to left front!!! no registration.where might i find the vin#?
look at the back of your doghouse. If there is a hump the vin number will be there. If it doesn't have the hump you need to take the front of the dog house off and clean off the gunk and you should then see the vin on the floor. I had the same problem with my 65 Econo Van.
I said in another post the cross brace at the back corners behind the taillights. either the left or right. Also has the serial number stamped on them. Usually it is the left one.
