Powerdyne Superchargers
Old 11-14-2009, 11:00 PM
dadlovesfords's Avatar
dadlovesfords
dadlovesfords is offline
Anyone have any info or opinions about these SCs? I am thinking about getting one for my 5.4 in my truck. It is a centrifical design blower unit that is non-intercooler equipped. It is for the 5.4 F150s.
Thanks ,
Larry
Old 11-15-2009, 09:12 AM
Blurry94's Avatar
Blurry94
Blurry94 is offline
The bd-11a works fine for stock appications as long as it's not overspun with a larger crank pulley or smaller compressor pulley. Keep the applications around 6-7 psi and it'll live for a while.
The XB-1a willl support more power than the bd-11a; it;ll move more air and at lower discharge temps. It's gear driven instead of belt driven like the bd model and it'll withstand as much as 18psi.
Old 11-15-2009, 10:25 PM
dadlovesfords
I think it is setup with pulley for 9psi boost. You think it will be ok , or should I look for something else?
Old 11-15-2009, 10:47 PM
Blurry94's Avatar
Blurry94
Blurry94 is offline
I wouldn't push it past that. Double check your spark plugs to make sure they're tight since spark plug ejection is a problem with the earlier 5.4's. At that boost pressure, it may be a good idea to run a set of plugs that are one heat range cooler than stock as well
Old 11-15-2009, 11:26 PM
dadlovesfords
Thanks for the help! This will be my first try at SC induction. Need all the help I can get!!Already been thru the popped plug routine with the Expy. Did the insert and it worked great. I'll get the cooler plugs that you suggested right away.Thanks again!!Larry
Old 11-16-2009, 03:11 PM
1Aauto's Avatar
1Aauto
1Aauto is offline
Former Vendor
Larry did you check to see if Vortech had one for your application ?
Old 11-16-2009, 07:41 PM
Blurry94's Avatar
Blurry94
Blurry94 is offline
I say, I wouldn't push past 9psi, if it's the bd model. The XB will handle more power and pressure, so 9psi, or more, wont be a problem if the kit is equipped with the XB compressor. I'd also suggest taking advantage of some aftermarket tuning to get the fuel and spark advance under control, before you get too happy with the throttle.
Old 11-17-2009, 09:05 AM
1Aauto's Avatar
1Aauto
1Aauto is offline
Former Vendor
Here's the Vortech for your application. Check out Jegs or Summit to see how much they want for it.
1997-2003 Ford F-150, Expedition, Navigator 5.4L 2V Supercharging Systems | Vortech Superchargers
Old 11-17-2009, 10:41 PM
Blurry94's Avatar
Blurry94
Blurry94 is offline
The Vortech is an excellent compressor (I still run one), however, the Paxton NOVI 2000 will move more air for about the same or less, for that make and model.
Old 11-18-2009, 10:41 AM
1Aauto's Avatar
1Aauto
1Aauto is offline
Former Vendor
Vortech also has the new V3 head that's self contained. I was a dealer for Vortech for 4 yrs before coming on board over here.Never had an issue with anything from them.It's good stuff.
Old 11-18-2009, 07:39 PM
Blurry94's Avatar
Blurry94
Blurry94 is offline
Are you saying that Vortech has a V3 kit for a 2000 F-150/5.4?
The V2 and V3 have about the same flow/pressure ratings at the same impeller speeds. However, having a self contained lubrication system is simpler than running feed and return.
Old 11-24-2009, 09:31 PM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD
BURNSTOUGHFORD is offline
For that much money why wouldnt you go with a Scerw type supercharger. They provide better boost and require less HP to make it from what im told. And they can be found in the 4-5k range.
Enlighten me, maybe im wrong.
Old 11-25-2009, 08:27 AM
1Aauto's Avatar
1Aauto
1Aauto is offline
Former Vendor
Not sure if the V3 is offered for that app. The return lines no biggie.Vortech does make a nice product though.
homertwo
WTB - Parts & other
06-17-2017 11:30 PM
lshort
1999 to 2016 Super Duty
05-02-2017 08:27 PM
atvracer557
08-31-2016 09:00 PM
7mag
03-08-2009 07:18 PM
meyerj
Modular V8 (4.6L, 5.4L)
04-02-2007 02:54 PM
Quick Reply: Powerdyne Superchargers
