Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #46 (permalink)
Old 11-18-2009, 01:05 AM
fyrbrd fyrbrd is offline
fyrbrd is starting off with a positive reputation.
Duck,
It may be nothing, but how thick is the oil? Are we talkin cold maple syrup, or warm syrup? If the oil is too thick wouldn't that affect the injectors operation? I didn't notice whether or not you checked the HPO pressure, what is it at? When it shuts down, are you noticing other indicators of possible electrical failure?
Keep us up to date...
Fyrbrd
  #47 (permalink)
Old 11-18-2009, 07:30 AM
MADVAN's Avatar
MADVAN MADVAN is offline
MADVAN has a good reputation on FTE. MADVAN has a good reputation on FTE.
Cody
The intake charge can get contaminated by that dead hole.
Keep in mind also that the pcm has the capability of changing
the idle tune as the motor ages. It does this to maintain a idle rpm.
IE: ex valve---The 3 cyl's that share the ex mani can fill the dead hole
and track to the intake of the motor. Think of it like how a gasser would run
with a bad egr valve. Now the intake track is contaminated along with the
pcm making adjustments trying to maintain a idle rpm.
Pressurise the dead hole (atdc) from the gp with shop air. Find the leaks.
It will give an idea on what is going on. (top or bottom end)
This is my keyboard wag.
Bill
__________________
97 4X4 PSD Quigley
  #48 (permalink)
Old 11-18-2009, 08:39 AM
powerstroked162's Avatar
powerstroked162 powerstroked162 is offline
powerstroked162 is gaining momentum as a positive member of FTE. powerstroked162 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by MADVAN View Post
Cody
Bill
This is great advice
__________________
DI Performance
Beans Diesel
Stecher Perfomance
Hellmann Performance
  #49 (permalink)
Old 11-18-2009, 09:04 AM
CampSpringsJohn CampSpringsJohn is offline
CampSpringsJohn is a splendid one to behold CampSpringsJohn is a splendid one to behold CampSpringsJohn is a splendid one to behold CampSpringsJohn is a splendid one to behold CampSpringsJohn is a splendid one to behold CampSpringsJohn is a splendid one to behold CampSpringsJohn is a splendid one to behold
How long does the truck sit before it will start back up? I'm thinking a relay is getting hot and shutting it off, then cools down and will allow it to start back up.
__________________
1997 Super Duty, PSD,6637, high idle, 50hp, & 80hp. 150cc injectors.
2002 F250 Crew Cab, 8' bed, 4X4, PSD, 6637, 4" magnaflow exhaust, high idle, 50, 75 tow, 100, 120, & 140, HPX Crossover
Kentucky Chapter Member
  #50 (permalink)
Old 11-18-2009, 09:18 PM
c00nhunterjoe's Avatar
c00nhunterjoe c00nhunterjoe is offline
c00nhunterjoe has a very good reputation on FTE. c00nhunterjoe has a very good reputation on FTE. c00nhunterjoe has a very good reputation on FTE.
can we get a scanner on it? that would make things 99.9% easier to diag. its either the pcm not commanding fuel, the high pressure oil system failed, the fuel system failed or the base engine causing the failure. the scanner will either rule out the first 3 causes or verify which one.
__________________
The name's Joe. I blow sheet up for a living, then get paid to fix it, and blow it up again.
http://www.youtube.com/user/c00nhunterjoe
http://community.webshots.com/user/c00nhunterjoe
  #51 (permalink)
Old 11-19-2009, 08:10 AM
MADVAN's Avatar
Base failure.
Bill
__________________
97 4X4 PSD Quigley
  #52 (permalink)
Old 11-19-2009, 07:31 PM
Base failure.
Bill
x2
Cowboy Steve
__________________
DI Performance
Beans Diesel
Stecher Perfomance
  #53 (permalink)
Old 11-19-2009, 08:36 PM
i kow, i think the dead hole is a huge contributor as well but the pid data will give concrete evidence
__________________
  #54 (permalink)
Old 03-17-2010, 02:27 PM
strokersace's Avatar
strokersace strokersace is offline
strokersace has a good reputation on FTE. strokersace has a good reputation on FTE. strokersace has a good reputation on FTE.
What ended up being the outcome on this?
__________________
Ryan
95 F350 CC Dually psd auto; A bed full of parts - motor comes out next week, then the work begins!!!
To have: 38gal tank, AirDog, Electric fuel, Stage 2's, Tapercore I/C, 6.0 trans cooler, Hydroboost Brakes, Electric vacuum, SD conversion, SD brackets/accessories, custom wiring, and much more...
  #55 (permalink)
Old 03-17-2010, 10:07 PM
RubberDuck's Avatar
RubberDuck RubberDuck is offline
DeathRowDiesel Inmate #1
RubberDuck has a great reputation on FTE. RubberDuck has a great reputation on FTE. RubberDuck has a great reputation on FTE. RubberDuck has a great reputation on FTE.
Good call Ryan. The guy just ended up letting the truck go back to the bank. After all the work and searching for an answer I was informed that it was repo'ed. Nice, and the guy didn't even tell me. Thanks for all your help guys, and I'm sorry that I never found an answer.
__________________
RubberDuck
1995 F350 Crew Cab 4x4 dually
DIY Stage 2's/T.E. SD HPOP/RSB Diesel 140v IDM/1st Valair 3800# OBS Double Disk clutch/DP Tuner 2 pos. w/ custom switch/Gear Vendors OD/Good bye No.3 I'll miss you.
RIP #17
  #56 (permalink)
Old 03-17-2010, 10:45 PM
Jacksfirstdiesel Jacksfirstdiesel is offline
Jacksfirstdiesel is starting off with a positive reputation.
Cody, I followed this thread thru to the end. I just think you (and everybody else that posted their thoughts for that matter) went way above and beyond. Sent rep's (first time-just figured it out) I really wanted you to get this one going for the guy-even if he just drove it like he stole it and fried the #7 hole due to his own negligence. I feel a little cheated not being able to help out a little. You must feel absolutely USED. So Again- I commend your persistence. You oughta go buy it from the bank for a song fix it and offer to sell it back to the guy (for a tidy profit) just for the satisfaction HA!
  #57 (permalink)
Old 03-17-2010, 11:29 PM
RubberDuck's Avatar
Na, I'd just like to put a fist in his mouth. I really went out of my way for this guy, and had to find out through a friend what happened. But, I look at it this way, he buys the truck for $3500 or whatever it was and the bank had to take it......he's got more issues than I can give him. His life is hard because he chooses it. Good riddence.
__________________
RubberDuck
RIP #17
  #58 (permalink)
Old Yesterday, 12:36 AM
No worries. I'm looking at a truck for sale pretty cheap that all of a sudden one day just wouldn't start. Supposedly had it towed to a local shop that did a compression test and found #8 hole is dead. They said either a hole in the piston or a bad valve. Never got it running and gave up and now he's selling.
Guess it was running just fine, no smoke, no miss, no using/burning of oil before. He said the hpop level is good, fuses are good, etc. He did say that he had 1 injector replaced last year and is pretty sure the dead hole is the same one the new injector was installed in. Thought that was ironic.
Just trying to figure out what it could be if I buy it cause the body is good.
__________________
Ryan
  #59 (permalink)
Old Yesterday, 12:44 AM
RubberDuck's Avatar
Man, I'd have to witness a compression check. If it were good, everything else could be fixed without motor removal.
__________________
RubberDuck
RIP #17
  #60 (permalink)
Old Yesterday, 02:28 PM
foxracing0934's Avatar
foxracing0934 foxracing0934 is offline
1997 Ford F-350
foxracing0934 is starting off with a positive reputation.
wow that sucks to hear, after all the help that you gave the guy he doesn't even have the comon curtusey to tell you that you don't need to worry about it anymore. That's a low blow, and he deserves everything he gets.
__________________
Richard
97 F-350 w/96,*** miles
DP Tuner, S.S. HPX Line, 4in MBRP, FPR shim, Dipricol Gauges (Tranny, EGT, Boost), 6637 Intake, Rosewood Stage II's, 6.0 I/C, 5" mitre cuts (6" soon though)
Soon to Come
Built Transmission, H-11 studs, H2E, wheels and tires.
Tags
1997 , 73 , ipr , sensor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
