1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
1998 Expedition Fuse Box Diagram
Old 11-14-2009, 06:41 PM
dino360's Avatar
dino360
dino360 is offline
My cigar lighter, and power points are not working on my 98 Expi I just bought. Does anyone have a digram for the fuse box? I have searched the net but can't find the correct one? Thanks
Old 11-14-2009, 07:40 PM
madsonp's Avatar
madsonp
madsonp is offline
It's in your owners manual, see page 130. If you don't have your owners manual here it is. http://www.motorcraftservice.com/pub.../98exdog1e.pdf
Old 11-15-2009, 10:22 AM
dino360's Avatar
dino360
dino360 is offline
I just bought the truck and it didn't have a manual. I tried that link but it seems to be invalid. Does anyone else have any suggestions as to where I can find a fuse box diagram? Thanks
Old 11-15-2009, 10:36 AM
dino360's Avatar
dino360
dino360 is offline
I had to register with the site in order to view the page. I found the info. Thanks
Old 02-20-2011, 12:41 PM
darklestat79's Avatar
darklestat79
darklestat79 is offline
where is fuse to disarm alarm
Old 02-20-2011, 12:42 PM
darklestat79
on a 97 ford expedtion
Old 02-20-2011, 08:23 PM
smac22's Avatar
smac22
smac22 is offline
darklestat,
If there is an alarm added on to the factory keyless, there will be a module installed under or to the left side of the steering column under the dash. There will be some wiring leading to that square box that will have in line fuses that you can pull. NOTE: most systems are wired in a way that if you remove the fuse to the alarm system the vehicle will not start. You will have to reconnect a wire that has been cut in the ignition wiring (gives power to the starter). You will see 2 wires from the alarm module go to each end of the cut wire under the dash. If I remember correctly, the wire may be white with a pink stripe.
smac22's Avatar
smac22
smac22 is offline
darklestat,
Stuck in germany
1999 to 2016 Super Duty
25
06-19-2022 11:43 PM
robengel
08-19-2015 03:54 PM
Viperfoxbat
06-25-2015 08:20 AM
BaronVonAutomatc
Electrical Systems/Wiring
04-20-2010 06:38 AM
deepbass
1978 - 1996 Big Bronco
12-09-2005 08:57 AM
Quick Reply: 1998 Expedition Fuse Box Diagram
