1998 Expedition Fuse Box Diagram
darklestat,
If there is an alarm added on to the factory keyless, there will be a module installed under or to the left side of the steering column under the dash. There will be some wiring leading to that square box that will have in line fuses that you can pull. NOTE: most systems are wired in a way that if you remove the fuse to the alarm system the vehicle will not start. You will have to reconnect a wire that has been cut in the ignition wiring (gives power to the starter). You will see 2 wires from the alarm module go to each end of the cut wire under the dash. If I remember correctly, the wire may be white with a pink stripe.
darklestat,
BaronVonAutomatc
Electrical Systems/Wiring
04-20-2010 06:38 AM
