How much horsepower can a 53-56 Frame hold?
Curious to know how much horsepower a 53-56 frame can hold in its original flex frame style
I would like to do a 4 link in rear and ifs up front so would do some boxing up then but I would like to run it with a engine tranny first for a while before spending that much more money
Engine is a 408W with about 450-500HP
Hi have a 51 with a 390PI @ about 400hp. The frame being semi boxed seems to be holding it just fine.
But, I've snapped an aftermarket tube under type motor mount, and beaten the stock spring on the passenger side to death.
If you box the frame from front to cab and have a good set of solid motor mounts built for it that are integrated with your IFS you shouldn't have any problems.
If you get a Mustang II IFS be sure you get at least 425# springs or higher.
Also, be sure, since you won't be using a stock transmission, that when you replace the transmission cross member, you box two feet front and back of that and have a strong new crossmember made.
armyaviation
18
07-18-2018 03:21 PM
armyaviation
06-14-2017 08:53 PM
gunder26
04-13-2016 12:10 PM
xfordman
12-16-2004 11:15 AM
