Just bought f-150, have some codes.
I am not as familure with this truck as i am with the one in my sig. So i dont know the common problems that go with codes. Thought maybe you guys would have some suggestions to problems that are normal with these codes.
Truck is a 94 Reg Cab Flare Side 4x4 5.8l/E40D
It has the fuel pump bypassed with a switch to turn it on manually. I will be looking into why they did this later. Probably the reason for one or more of the codes.
Fast code
542 - fuel pump secondary
332- egr flow low
172-ego lean
Slow code
542
Like i said some reason the fuel pump is bypassed from the key start. It has a manual switch. I will be looking into the factory wires to see if i have contenuity back to the fuel pump. They ran a wire all the way to the rear from the battery and have a switch inline to shut it off. Very wierd
Egr low is either the egr tube is pluged or rusted out. or the egr valve is bad i figured. Any other solutions?
Fast code
332- egr flow low
172-ego lean
Slow code
542
You did not say what kind of codes these were.
It would help to know if they were KOEO, CM or KOER codes.
I have no idea what you mean by Fast code or Slow code.
DTC 172 The right or rear HO2 Sensor indicates system is running lean.
The 332 code has nothing to with flow.
DTC 332 in Key On Engine Running (KOER) indicates the EVP sensor input did not change after the EVR solenoid was instructed by the Powertrain Control Module (PCM) to open the EGR valve.
Possible causes:
--Vacuum hose leaks.
--Icing.
--Obstructed vacuum hose.
--Obstructed EVR solenoid filter.
--Damaged EVR solenoid.
--Damaged EVP sensor.
--Damaged EGR valve.
Continuous Memory (CM) DTC 332 indicates the EGR valve did not open with the engine stabilized and the EVR solenoid duty cycle present sometime during vehicle operation.
Possible causes:
--Obstructed or cracked hose to EGR valve.
--Icing.
--Damaged EVR solenoid harness.
DTC 542 Key On Engine Off (KOEO) indicates that one of the following has occurred:
No Start:
--Inertia Fuel Shutoff (IFS) switch not reset or electrically open.
--Open circuit between the fuel pump and FPM circuit connection to the power-to-pump circuit.
--Poor fuel pump ground.
--Fuel pump electrically open.
Engine Starts:
--Fuel pump secondary circuit short to power.
--Fuel pump relay contacts always closed.
--Open in FPM circuit between PCM and connection to the power-to-pump circuit.
--Left/front HO2S short to power (dual HO2S applications).
--Damaged Powertrain Control Module (PCM).
A Continuous Memory DTC 542 indicates that one of the following intermittent conditions has occurred:
--Fuel pump circuit activated when PCM expected circuit to be off (i.e., fuel system test or prime procedure).
--Inertia fuel shutoff switch tripped, then reset.
--Open circuit in or between the fuel pump and FPM circuit at the PCM (refer to «Schematic»).
--FPM or power-to-pump circuit short to power.
--Fuel pump relay contacts stuck closed.
--Left/Front HO2S circuit short to power (with/dual HO2S).
--Engine stall due to excessive load.
NOTE:
For trucks with dual fuel tanks, perform Key On Engine Off (KOEO) Self-Test twice, once with the front tank selected and once with the rear tank selected. If KOEO DTC 111 and Continuous DTC 542 is present both times, continue with this test (intermittent concern). If KOEO DTC 542 is present in only one test, refer to the Fuel/Engine Group of the Service Manual to check for open circuit between select switch and suspect pump circuit ground.
Possible causes:
--Icing.
Possible causes:
--Icing.
No Start:
Engine Starts:
NOTE:
Thanks for the help, hopefully i can get some time monday to look at it and report back. My guess is the guy that had it before me, probably wrecked it or somethign and tripped the fuel inertia shut off and didnt know how to re enable the fuel pump. So he just bypassed it. Im hoping that its that simple.
Where is the inertia fuel pump switch on these trucks. I now its by my passenger side right kick panel on my 99.
Thanks again
+ rep
Thanks again
+ rep
If your fuel pressure is in check, try running back-to-back bottles of fuel system cleaner if nothing else. Worst case, you burn $10-12.
Also check the exhaust manifold bolts. I found a loose one on mine this summer when I was changing spark plugs.
Edit- I just looked at my OBD-1 manual. It defines code 172 as "HEGO senor fault/lean." Could that mean that the problem is the O2 senor? I had a bad vacuum leak on my car, and it was throwing 189. Seems like you should be getting codes along the lines of 179, 181, 188 or 189 if a good senor was detecting a rich/lean condition... I could be mistaken though. How old is the O2 senor?
The cylinder balance test will only work on the SFI MASS trucks.
He has a MAP sensor so he can not run the test as his truck would be bank injected.
For the 172:
Possible Causes:
-- Fuel injectors.
-- HO2S.
-- Secondary Air Injection (AIR) system.
-- PCV/Hose.
-- Vacuum.
-- CANP.
-- MAP sensor.
-- Electronic Ignition Coil Failure.
For the 172:
Possible Causes:
-- Fuel injectors.
-- HO2S.
-- PCV/Hose.
-- Vacuum.
-- CANP.
-- MAP sensor.
